Old 12-31-2014, 01:27 AM   #21
Gooseloony
Gooseloony's Avatar
Default Re: Steering wheel light switches
Thank you Tom. I will have to order a spider but will post on here when I get it all back together (fingers crossed). I will also get the tool if you think that will help with the reinstall.
Gooseloony is offline   Reply With Quote
Old 12-31-2014, 02:09 AM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
I haven't used the tool, but it looks like it would help. I push the spider up and use a small pencil magnet to lower the clip into place. It can be hard on the hand though.
Old 12-31-2014, 06:09 AM   #23
29spcoupe
29spcoupe's Avatar
I have used that tool and it helps tremendously. John
29spcoupe is offline   Reply With Quote
Old 12-31-2014, 11:09 AM   #24
Gooseloony
Gooseloony's Avatar
Thanks for the confirmation John. Do you still own the Coupe in your avatar?
Old 12-31-2014, 11:16 AM   #25
Will N
Will N's Avatar
Originally Posted by rocket1 View Post
possibly the snap ring or horse shoe clip that holds spider in position is missing.
We refer to that clip as the Jesus clip. That's because when you try to instal it, you will invariably take the name of the Lord in vain.
Will N is offline   Reply With Quote
Old 12-31-2014, 11:16 AM   #26
Kahuna
Kahuna's Avatar
29Coupe is right
That tool is a life saver
Kahuna is offline   Reply With Quote
Old 12-31-2014, 11:19 AM   #27
Michael M
Michael M's Avatar
I used Tom's trick with the yardstick holding down the horn / light switch. Works great! It's like having a second pair of hands.
Michael M is offline   Reply With Quote
Old 12-31-2014, 01:19 PM   #28
CarlG
CarlG's Avatar
You might consider ordering up several extra "C" clips. They are cheap and very hard to find when everything goes flying while trying to get everything installed.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-31-2014, 01:29 PM   #29
Tom Wesenberg
Just be sure to prefit them to the spider and to the rod notch before you spend a half hour fighting a no fit problem, like I did a few years ago.
Old 01-09-2015, 12:22 PM   #30
jwaldrich
jwaldrich's Avatar
I was wondering about the grease in the photos as well. In my mind grease and electricity do not play well together and when you are only starting with 6V to begin with I would think there would be a voltage drop as it worked it's way through the grease.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 01-09-2015, 03:11 PM   #31
29spcoupe
29spcoupe's Avatar
goosloony, I still have the coupe. I have only owned it for about 4 1/2 months. Love it!
John
Old 01-09-2015, 07:03 PM   #32
Steve Plucker
Gooseloony,
There is a Model A Club in Fresno...Are you aware of that?
Maybe someone in the club can give you a hand.
Pluck
Old 01-09-2015, 10:49 PM   #33
Gooseloony
Gooseloony's Avatar
Originally Posted by Steve Plucker View Post
Gooseloony,
Pluck
Yea Pluck I do and I am thinking of searching it out. Thank you
Old 01-13-2015, 12:02 PM   #34
burner31
burner31's Avatar
The spider should fit easily over the square light rod, some of the new repo spider are tight and WILL break the ears when you try to force it over the rod, take a small flat file and file the ID of the spider until it slides over the rod. Ask me how I know this.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
