Old 06-23-2019, 12:12 AM   #1
Russ/40
Russ/40's Avatar
Default Pulling the Pinion
What are you guys using to pull the pinion on V8 center sections?
Old 06-23-2019, 12:42 AM   #2
ford38v8
ford38v8's Avatar
Default Re: Pulling the Pinion
Use a press. Easy peasy.
Alan
Old 06-23-2019, 07:27 AM   #3
john in illinois
john in illinois's Avatar
Yup. Here is the set up I use.
John
File Type: jpg 65000ACC-A08C-4E8B-AD86-A63F2FA234D5.jpg (52.1 KB, 86 views)
Welcome each day
john in illinois is offline   Reply With Quote
Old 06-23-2019, 10:39 AM   #4
Russ/40
Russ/40's Avatar
Thanks! Got a press, but it's only 3 1/4" opening. I guess I could build another shelf with a wider opening.
Old 06-23-2019, 11:40 AM   #5
Angledrive
Angledrive's Avatar
Heating the housing to about 200 degrees helps also.
Angledrive is offline   Reply With Quote
Old 06-23-2019, 11:57 AM   #6
john in illinois
Also when putting it back in, if you freeze the pinion and heat housing it usually drops right in. And heat definitely helps it come out easier.
John
Welcome each day
Old 06-23-2019, 02:07 PM   #7
Mart
Mart's Avatar
It would probably be worth modifying the press so it can be opened up wider than the normal size if need be. Mine has two channel sides held together with bolts and tubular spacers. Quite often I loosen the bolts to accommodate something wider. I used my press in a similar way to that pictured above.
Mart.
Old 06-24-2019, 09:20 AM   #8
Ken/Alabama
Ken/Alabama's Avatar
This is the tool I have.
File Type: jpg 0343F064-8D52-4FD9-84C2-CE06E2E1A92F.jpg (42.8 KB, 24 views)
File Type: jpg C5B15E0C-2CD3-4AE1-8141-1FF16EDF2FF5.jpg (40.3 KB, 20 views)
Old 06-24-2019, 09:42 AM   #9
Russ/40
Russ/40's Avatar
Interesting Ken, does your work by tightening the nut? The center shaft has threads not visible in the photo? Also what did you use for the arch?
