Old 06-14-2019, 03:19 PM   #1
New24ords
Default Cracked 1949 8BA
Does anyone know if this is anything to be concerned about. It will be heading in for further inspection.[IMG]img 0894[/IMG]
New24ords is offline   Reply With Quote
Old 06-14-2019, 03:21 PM   #2
JSeery
JSeery's Avatar
Default Re: Cracked 1949 8BA
Edit: Photo showed up after a delay for some reason.
Old 06-14-2019, 03:27 PM   #3
New24ords
I can see the picture
Old 06-14-2019, 03:29 PM   #4
JSeery
JSeery's Avatar
It just showed up on my computer as well. The crack between the bolt hole and the water passage shouldn't be an issue. The one traveling up from the bolt hole should be drilled at the end as a minimum. Pinning it would be better. There are several posters on the Barn that are much more knowledgeable than me on cracks and repairs. Might check with your machinist and see what his experience/capabilities is/are.
Old 06-14-2019, 03:42 PM   #5
New24ords
I was thinking about drilling the one crack heading up
Old 06-15-2019, 12:04 AM   #6
Russ/40
Russ/40's Avatar
I'd leave it alone and run it.
Old 06-15-2019, 12:23 AM   #7
tubman
tubman's Avatar
You know Russ? I think I agree with you. It looks like it's been there forever and is quite stable; doing anything might upset the equilibrium.
Old 06-15-2019, 09:51 AM   #8
Russ/40
Russ/40's Avatar
Well, as they say - great minds work alike.
Old 06-15-2019, 11:15 PM   #9
Pete
Pete's Avatar
It depends on how much you are willing to gamble. If it fails, it will be EXPENSIVE.
It is an easy cheap fix to pin it.
Old 06-16-2019, 09:29 AM   #10
rotorwrench
rotorwrench's Avatar
Once a crack gets started, it rarely quits growing. A few times getting hotter than it should, which we all know can happen on flatheads, may spread the crack into an exhaust valve pocket. It will be a lot harder to fix then.
Old 06-16-2019, 12:38 PM   #11
philipswanson
A good machinist can drill it and pin it. Otherwise it will keep traveling.
philipswanson is offline   Reply With Quote
