Old 11-25-2016, 06:35 PM   #21
av8coupe
Default Re: Stromberg BIG 97
I think that would be a Stromberg 48. Dave
av8coupe is offline   Reply With Quote
Old 06-05-2019, 10:21 AM   #22
Tim Brown
Tim Brown's Avatar
Running this back up to see if anyone is running a Single Big 97 and what jets and power valves are working. They ship out with #56 jets in them.
Tim Brown is offline   Reply With Quote
Old 06-05-2019, 12:08 PM   #23
Russ/40
Russ/40's Avatar
If someone wouldn't mind, i'd like a tutorial on 2" hg depression. What is the "depression" concept.
Old 06-05-2019, 12:25 PM   #24
deuce_roadster
deuce_roadster's Avatar
Maybe Lincoln Jim in Wisconsin?
Old 06-05-2019, 01:10 PM   #25
Pete
Pete's Avatar
Recently I furnished the valve train for a 304 that is running 3 big 97's.
It could use a 4th because it is pulling about 2 inches of vacuum.
Knowing the owner though, he may opt for electronic Hilborn's instead.
Old 06-05-2019, 02:04 PM   #26
scicala
scicala's Avatar
The 2"hg depression being talked about is how a flow stand is set up to measure total CFM air flow capacity at a manufacturer's facility or other business. 2"hg is the same as 2" of manifold vacuum (mercury = hg).
When flowing a carburetor, after mounting the carburetor on a flow stand, you open the carburetor to wide open throttle (WOT) and adjust the vacuum pump for 2"hg or any other amount you want. When I worked at Zenith Carburetor in Detroit we used 2"hg as the standard. Then when at WOT at 2"hg, the air flow going through the carb was measured (CFM). The higher the depression, the higher the air flow.
Holley measures two barrel carbs at 3"hg depression and four barrel carbs at 1 1/2 or 2" depression. That is why they say a two barrel Holley carb with the same size venturi's and throttle bores flows more air than a four barrel carb (just two of the barrels) with the same size venturi's and throttle bores.
To me this just makes things confusing and comparing apples to oranges sometimes.
Sal
scicala is offline   Reply With Quote
Old 06-05-2019, 02:08 PM   #27
Tim Ayers
Hey Pete:
Wondering if you could provide more details about valve train work you did?
I'm starting to think two "regular" 97's won't be enough on my 296.
Thanks,
Old 06-05-2019, 02:18 PM   #28
Pete
Pete's Avatar
Originally Posted by Tim Ayers View Post
Hey Pete:
Thanks,
404A cam. Drilled radius lifters. Bronze guides. Titanium 1.7 dia. valves. 4 turn springs with dampers. Titanium retainers.
2 regular 97's will work fine for mild street driving and parades.
Old 06-05-2019, 02:22 PM   #29
Tim Ayers
Haha. Yeah, I'm no where near that beast you built. 1.6" valves, full porting and relief work.
Old 06-05-2019, 06:30 PM   #30
Russ/40
Russ/40's Avatar
Sal, thank you for the explanation, much appreciated.
Old 06-06-2019, 07:21 AM   #31
swanwaco32
I have installed them on a 383 small block chevy after having tripower with Rochester's and they do flow a lot more than the 2g Rochester's..!! Not sure the flathead would take it??
swanwaco32 is offline   Reply With Quote
Old 06-06-2019, 08:38 AM   #32
Bored&Stroked
Bored&Stroked's Avatar
Well that type of driving DOES NOT include me! LOL Hope all is well with you Pete - haven't chatted in awhile, I think we need too. I have two 48's on my 284 CI engine, is far too little. I'm sticking with this manifold for now (due to the build period, but it is NOT optimal).
I'm going to port another "spare" Eddie Meyer top and first try two Holley 2110's (on an engine dyno - want to see if the flow helps), then I'd like to try two Big 97's. Would be a fun experiment.
Take care my ole' friend.
D
Old 06-06-2019, 08:57 AM   #33
tubman
tubman's Avatar
How do you arrive at this conclusion? As far as I have ever known, a small base 2G flows about 275 cfm, while these are rated at 250 cfm.
While these may be alright to use on an SBC manifold, I believe that there may be problems on standard, 3-bolt Ford manifolds. I am very partial to 2G's on a street flathead in a car with a hood. I have found that, while the Mercury manifolds have enough "meat" in them to permit them to be bored all the way down to 2GC size, most Ford manifolds won't take it. I suppose this may not be a problem with "racing" manifolds without provision for exhaust heat, but I would not want to "roll the dice" on a heated Ford manifold. Just one more thing to consider. Unless you bore the manifold to match the throttle bores on the carburetor all the way (and possibly radius the corners like I do), you will not get full benefit of the larger carburetors.
Old 06-06-2019, 01:01 PM   #34
revkev6
D
Interesting that you are trying this dale. I'm building a blower setup and want to stick with 2x2 on it because three looks too crowded on the Eaton m112. I picked up a really nice 2110 that I need to find a match for. 1 5/32 venturis. Manual choke with plugged valve factory. Havent seen another like it. Basically looks like a big bore replacement for a 94
revkev6 is offline   Reply With Quote
Old 06-06-2019, 01:07 PM   #35
Tim Ayers
I wonder if this is a what was called the Bug Spray carb? Bug Sprays were used on VW's when putting a performance 2bbl. set up on the car.
Old 06-06-2019, 01:52 PM   #36
revkev6
i looked up the number and it wasn't a bugspray carb. pretty sure it was an oem ford unit or replacement from the 50's. the bugspray units have electric choke if I'm not mistaken.
Old 06-06-2019, 03:13 PM   #37
Ol' Ron
Ol' Ron's Avatar
Does amybody have any idea what the two 2GC carbs floe. The make the small onr that bolts to the Merc intake and a larger one. I've never seen any data on them, Or forgot??
Ol' Ron is online now   Reply With Quote
Old 06-06-2019, 04:12 PM   #38
revkev6
Tubman said the small base is 275 a couple posts up
Old 06-06-2019, 04:39 PM   #39
Tim Ayers
Hmmm. I had what I thought was a Bug Spray on my VW and it had a manual choke. You are probably right. I was a dumb kid when I owed it. Haha.
Old 06-06-2019, 05:38 PM   #40
scicala
scicala's Avatar
I think there were also different venturi sized small base 2 GC's, since they went on a lot of different size engines on GM and marine engines.
So probably the 2GC's from larger engines flowed 275 CFM.
Sal
