08-05-2015, 02:26 PM | #1 |
evap-o-rust
Just cleaned my 53 victoia cooling system, I bought 3 qts 1 year ago , in quart container, on the container it said to use one quart per gallon of water replaced. I did this, ran for an hour on the highway @ 75 mph, didn't heat up, I decided to call evap-o-rust wondering if I could leave it in and run it tomorrow. He said I should use it straight then drive to normal temp, let it set for 5 hrs. What have you guys done?
08-05-2015, 03:01 PM | #2 |
Re: evap-o-rust
Interested also, as I'm about ready to do the same on my 39.
Chatted with Bruce L. He thinks using it straight and leaving is a good idea. I think the same. We'll see |
08-05-2015, 03:21 PM | #3 |
Re: evap-o-rust
08-05-2015, 03:37 PM | #4 |
Re: evap-o-rust
Its very good...just dont overdo it...any small crack with rust in now being sealed will open up.
Fill it up. Run it. Drain out the sludge and let the sludge go too the bottom of a container reuse the rest. Flush system. Inspect if needed do it over again. Better to flush out the system a few times trying to keep it out of the radiator then running it for a real long time. |
08-05-2015, 04:12 PM | #5 |
Re: evap-o-rust
Just to clear things up a little, my evap-o-rust says concentrate. It seems to be working, I will let you know tomorrow, I will leave in overnight, then drive it and see what happens.
08-05-2015, 04:16 PM | #6 |
Re: evap-o-rust
08-05-2015, 05:10 PM | #7 |
Re: evap-o-rust
Just came back from a run the radiator when I left was kind of brown, ran for about 20 mins got back fluid is black, its working. Let you kow tomorrow how it comes out.
08-05-2015, 07:28 PM | #8 |
Re: evap-o-rust
Drain it, give plenty of time to settle like in a 5 gal bucket. Leave all rid in bottom and reuse it again. You will get clean after a couple of times. However, I do caution you, if you had a crack, you will have opened it up. Proceed w caution. This stuff is pretty Good undiluted. Much getter than vinegar! Two different rust removal processes. Vinegar is light acid, evaporust is chelation
08-07-2015, 08:28 AM | #9 |
Re: evap-o-rust
latest update: flushed complete system 2 times water ran clear, first drain black left alot of residue, filled radiator with pure water, ran until normal operating temp about 180 deg, drained and flushed. put in antifreeze plus 2 bottles of water wetter, took for a drive temp 190 deg. water seems to run cooler. may try test with plain water with lube.
08-07-2015, 08:37 AM | #10 |
Re: evap-o-rust
What thermostats are you running?
08-07-2015, 01:43 PM | #11 |
Re: evap-o-rust
160 degree thermostats, today I drove it around 1 pm city and rural higher ambient temperature 89 degrees, humidity 57% engine temp 210 degrees. I am sure the humidity
has a lot to do with getting hotter. yesterday it was 85 degrees 90% humidity. Next I am going to use water with anti rust. I was running AC all the time. |
08-07-2015, 02:35 PM | #12 |
Re: evap-o-rust
Is your timing initial, curve, advance, up to specs?
08-07-2015, 02:57 PM | #13 |
Re: evap-o-rust
Have you tried to clean the core sand out of the block? This is running hot for 160 deg thermostats.
08-07-2015, 04:56 PM | #14 |
Re: evap-o-rust
My dist settings are 22 degrees @ 2200 rpms it a Mallory solid state ign.
No I have not tried to clean block. |
08-07-2015, 07:45 PM | #15 |
Re: evap-o-rust
Johnny
Did you continue to use the Evaporust in a diluted form, or straight. Thanks Jim |
08-07-2015, 08:38 PM | #16 |
Re: evap-o-rust
I think water wetter with water works but when mixed with antifreeze not so much.
Is there any chance of damaging water pumps or seals when using any of theses cleaning solutions? |
08-08-2015, 09:19 AM | #17 |
Re: evap-o-rust
I used it in diluted form my product was 1 year old and says concentrate on it. check website for things to avoid.
08-08-2015, 04:57 PM | #18 |
Re: evap-o-rust
Drained antifreeze, filled with water plus added anti rust. ran about the same temp 90 deg weather @ 75 mph in od it got to 210 deg. I will add wetter water and see what does.
08-08-2015, 05:34 PM | #19 |
Re: evap-o-rust
I just finished running Evaporust in the cooling system to clean the engine and radiator. I left it in for four days, running it up to operating temperature twice a day. I drained it out [it was black] and put it back into the 5 gallon bucket for later use. I flushed out the cooling system with water running the engine the entire time. I had both drain cocks wide open with hose in radiator. Water came out the top of the radiator and both drains. I hoped to flush out anything that had not been dissolved. After a long flushing session I shut it off and drained it.
I let it set while with the radiator cap off and both drains open hoping some of the water would evaporate out. After a few hours I filled it with Evans Waterless Coolant. I only took it for a drive of a few miles, but it seems to cool fine. The good thing is there will be no more rust ever!
John Live for today, but save for tomorrow! |
08-08-2015, 05:45 PM | #20 |
Re: evap-o-rust
Here's another great product. - http://www.rust911.com/ and also at
http://www.rust911.com/photo-gallery/ I used this stuff in my '34 with aluminum heads and it did the job....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-08-2015 at 05:52 PM. |
Thread Tools | |
Display Modes | |
