07-06-2017, 01:08 PM | #1 |
Condensers
The condensers made today are about 1/8 inch longer. At least the good ones made by A and L. are.This places the copper screw head very close to the distributor housing.If you use a longer screw and place a nut under the condenser between it and the housing it moves the condenser away from the housing. This gives you a nice gap between the copper screw head and the housing and also allows room to install the the little rubber button that they are now selling to plug the hole.
07-06-2017, 02:04 PM | #2 |
Re: Condensers
The good quality condensers sold by the majority of the quality suppliers are slightly longer than those of yesteryear. I also encountered this problem early this year with a late 31 casting. These castings are visibly identified with having a bridge across where the snap arms are adjoined. The casting are also slightly more robust and can be found to have a protrusion on the inside of the casting where the condenser attaches to the lower plate.
The attached article was published in the Victoria Bustle publication of April 2017 and explains my encounter with this problem. The original poster's idea of placing some type of spacer under the fiber washer seems to be a viable alternative and good idea. Tom Endy |
07-06-2017, 07:52 PM | #3 |
Re: Condensers
Thanks Tom for the article. You always have great information!
07-07-2017, 11:59 AM | #4 |
Re: Condensers
Tom, what do you do w/all them rebuilt distributors? Sell them? Hoard them?
07-07-2017, 09:53 PM | #5 |
Re: Condensers
He 'distributes' them
07-07-2017, 10:13 PM | #6 |
Re: Condensers
1929 Model AA - Need long splash aprons! |
07-07-2017, 10:36 PM | #7 |
Re: Condensers
Tom is most likely the only Model A person we know who is knowledgeable enough to plant Model A distributors and raises new Model A distributors as a side line business.
Always great to hear from Tom. |
07-07-2017, 10:47 PM | #8 |
Re: Condensers
I bet he has a window box with them sprouting up from the mulch.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
07-08-2017, 06:07 AM | #9 | |
Re: Condensers
Or I'm reading the OP wrong. Let me know. .
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" Last edited by Jim/TX/GA; 07-08-2017 at 09:32 AM. |
07-08-2017, 06:17 AM | #10 |
Re: Condensers
Jim You are correct
07-08-2017, 01:51 PM | #11 |
Re: Condensers
That makes more sense now that I think about it.
Tom Endy |
08-01-2017, 01:31 PM | #12 |
Re: Condensers
I don't have my repair manual yet (It's ordered should be here soon) but this question has been bugging me. Where is the condenser. I don't have the one that sits up with the points so I'm guessing it is hidden elsewhere.
08-01-2017, 01:52 PM | #13 | |
Re: Condensers
I got my car a couple months ago and I have been trying to be a sponge trying to absorb a lot of information about A's. I have been more than familiar with a 64-1/2 Mustang that I owned for 25 years that I bought from my dad many years ago. Frankly, I am amazed at how similar the basic components are between the two vehicles, notwithstanding many years of changes in those years. That being said, use the search function and go to the club websites. Lots of stuff out there. Last edited by Magicbox51; 08-01-2017 at 04:16 PM. |
08-01-2017, 02:25 PM | #14 | |
Re: Condensers
The Search feature is how I found this thread. I'll have my repair manual soon and all will be well! |
08-01-2017, 03:15 PM | #15 | |
Re: Condensers
http://modelabasics.com/Ignition.htm
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
08-01-2017, 04:17 PM | #16 |
Re: Condensers
08-01-2017, 04:30 PM | #17 |
Re: Condensers
Changing the condenser is very quick and easy of you follow these steps exactly.
Lay the new condenser by the distributor. Remove the ground screw first, then go to the other side and unscrew the hidden screw. Keep light pressure on the hidden screw as you slip out the old condenser and slip in the new. Tighten the hidden screw, then walk to the other side and tighten the ground screw. |
08-01-2017, 05:13 PM | #18 |
Re: Condensers
I am sitting here reading all this and wondering if I am the only one that owns one or three of these? If I am, shame on the rest of you since the Model A is built with a LOT of slot top screws!
08-01-2017, 05:46 PM | #19 |
Re: Condensers
I have for both flat and phillips,,,they come in very handy in situations like these.
I forget where I got mine, it was about 50 years ago ;-)) |
08-01-2017, 05:58 PM | #20 |
Re: Condensers
I have one of those tools too. I use it all the time, and I did use it for changing my condenser after reading Tom W's instructions somewhere about two weeks ago.
There is another kind that I used to have that I really miss. Unfortunately this style has such a spring load to it, sometimes the screws go flying if it accidentally slips off its detent. The other type I have seen, but cannot find anywhere was kind of a clam-shell tip (best way for me to describe it). I used them in the military back in the '70's and I used to have one, but they seem to be made of unobtanium. |
