07-30-2017, 09:17 PM | #41 |
Re: No spark
i like the modern wire cap and rotor kit i got. I think it was from snyders.
07-30-2017, 10:56 PM | #42 | |
Re: No spark
oops, yes the points should be closed and zero volts. If you have a voltage and the points are closed you have dirty points. Thanks for the find! Unfortunately, the posts are too old to edit. In the future, I will copy the post with the change instead of pointing to the old post. Thank you again for letting me know.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 07-30-2017 at 11:02 PM. |
07-30-2017, 11:17 PM | #43 |
Re: No spark
With the clips off the distributor cap, the rotor spring pressure will lift it up slightly. If it doesn't, then the carbon in the center is likely too worn, and the cap should be replaced.
Those straps to the plugs should never need to be replaced, but if you do, then buy the bronze ones, as they have better spring action than the brass ones. |
