Old 09-27-2018, 09:46 PM   #1
Cape Codder
Cape Codder's Avatar
Default Grease Fitting Types and Locations
Is there anywhere that will tell me what type of grease fitting is installed i.e. screw in or press in at each position. Example: I have a fitting on my right rear shock missing but can't tell if it is a screw in or press in. Tried two different sizes and neither would start.
Any help would be appreciated!
Cape Codder is offline   Reply With Quote
Old 09-28-2018, 12:05 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Grease Fitting Types and Locations
There were no grease fittings on the shocks, it was a plug so oil could be added. Or are you asking about the tube type link?
Old 09-28-2018, 03:17 PM   #3
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
You should be able to feel inside the hole with a small wire or something and tell if there are threads or not. If the fittings you have won't start it's a good chance it's a press in hole. A lot of them were.
MickeyT is offline   Reply With Quote
Old 09-28-2018, 08:37 PM   #4
Cape Codder
I know there is no fitting on the shock, I was in error when I wrote it. I meant to say shock link.
But I'm still looking to find out if there is a list of all grease fittings and what type they are, press in or screw in, all over the car.
Old 09-28-2018, 09:23 PM   #5
Curtis in MA
Les Andrews red book pg 3-2
Curtis in MA is online now   Reply With Quote
Old 09-28-2018, 09:30 PM   #6
Cape Codder
Thank you very much Curtis in MA. I will check that out. I can't miss with that info having a page number also. Thanks again!
Old 09-28-2018, 10:19 PM   #7
24ruxstel1339
24ruxstel1339's Avatar
A lot of old stuff had 5/16" 24 fittings. I had a hard time matching some up for a 29 Harley.
They're available.
24ruxstel1339 is offline   Reply With Quote
Old 09-29-2018, 06:49 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
The Parts Price List should also show the fittings and tell which style each one is.
Old 10-01-2018, 12:09 AM   #9
Dodge
Don't forget the one on the muffler bearing, right Bill?
Dodge is offline   Reply With Quote
