03-16-2011, 09:30 AM | #61 |
Re: Thermostat
You should be adjusting your spark lever according to engine load and speed. Advance for high speed, retard for loading such as climbing hills or at idle speeds. If your car is properly timed there is a noticeable difference.
The GAV valve is adjusted according to engine temperature and engine speed. Operation of the spark and GAV is detailed in the owners manual |
03-16-2011, 11:29 AM | #62 |
Re: Thermostat
"Standard" instruction on the GAV is to close it fully, then open 1/2 to 1 full turn for starting from dead-cold, then to close it to 1/4 turn from closed once the engine is warm.
With my unrestored 84,000 engine, in cold weather I find I have to have the GAV open about 2 turns for the first couple miles, then can close it down to about 1/2 turn open. In the summer, I can run it 1/4 turn open. SC Frank |
03-16-2011, 11:58 AM | #63 |
Re: Thermostat
"With out a thermostat, you would get more heat out of a chicken."
Herm, I just lost my coffee all over my monitor just by imagining your statement. |
03-16-2011, 01:25 PM | #64 |
Re: Thermostat
I don't run a thermostat, and my car runs fine. Been thinking of putting one in there anyways to help keep it at 160* in the winter. My A runs better at 160* than it does at 180* even though most people say theirs run better at 180*. I have a centrifugally advanced distributor and a modern carb, so i dont have the ability to adjust the GAV or spark. But that's ok with me considering i like how these two modifications make the car run better in MY opinion. So i'm not going to change them to make the engine warm up faster. For now, i just stick the cardboard in front of the radiator.
