Old 04-03-2018, 11:31 AM   #1
teedog
teedog's Avatar
Default gas gauge gaskets
is it a good idea to coat gaskets with sealer on both sides ? im using cork. thanks for any help, mike
teedog is offline   Reply With Quote
Old 04-03-2018, 11:58 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: gas gauge gaskets
Believe it or not I've read suggestions to use maple syrup. A little drop of oil or grease wouldn't hurt.
Paul in CT
Old 04-03-2018, 12:25 PM   #3
1955cj5
1955cj5's Avatar
I've only rebuilt one gauge, but it doesn't leak.
The gaskets on either side of the glass lens went on dry.
A little sealer (Permatex #2) on both sides of the large cork gasket.
I used two thin brass washers with a tiny bit of light oil between them.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-04-2018, 09:35 AM   #4
burner31
burner31's Avatar
Rebuilt mine, no sealer, no leaks.
Hint: Do not use any parts from China for this area. You WILL have leaks!
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-04-2018, 10:47 AM   #5
mcorrell
mcorrell's Avatar
I just did this. Use no sealer. I used the neoprene gaskets, and two brass shims lightly coated with oil. No leaks and thanks to the new glass I can see the fuel level.
1929 (early) Model A Special Coupe - restored to original
1964 Buick Wildcat convertible
mcorrell is offline   Reply With Quote
Old 04-04-2018, 01:09 PM   #6
oldman - NorCal
oldman - NorCal's Avatar
As others have said, I went with cork gaskets and two brass shims. I would also recommend changing to the neoprene float if you currently have a cork float. Oh, and as 1955cj5 shows, use the higher quality stainless steel gas gauge tool to tighten everything up.
oldman - NorCal is offline   Reply With Quote
Old 04-04-2018, 03:01 PM   #7
larrys40
I have replace many and I would use the new neophrene float and wire it on with stainless wire.... and use the cork gaskets. Not need to coat it with anything. Just make sure you pick out the old one and any debris left. One brass ring between the gauge and outer ring is sufficient. Do the inner nut and gasket on the bench and tighten there before install to the tank.
I like using the original Ford 5Z gas gauge tool if availalble. If not use the aluminum ones so they don't mar the nuts.
Larry Shepard
larrys40 is offline   Reply With Quote
