05-11-2015, 09:01 PM | #21 |
Re: New mitchell overdrive
My friend with a '34 Tudor had to make a cut in the floor less than +/- 2 inches forward to accommodate the length of the gear box and it's width.
05-11-2015, 10:23 PM | #22 |
Phew .. guess it would be the weight that will be the real killer for transport to Australia..
I was hoping next trip to Cali I could just tuck it under my arm and walk on the plane with it
"Came too close to dying to stop living now!" |
05-12-2015, 04:57 AM | #23 |
I didn't have to cut any on my floor on my 40 but did reverse the cable hook up upside down because when someone was in back seat it would hit but I have Posie reverse eye spring on both ends.That just means I have to push in for OD not pull out cable.
05-12-2015, 10:17 AM | #24 |
05-12-2015, 11:10 AM | #25 |
05-12-2015, 12:12 PM | #26 |
05-13-2015, 11:38 AM | #27 |
I have one in my 33 3-w coupe. One problem on 33 very close to floor in rear.
when I first had the overdrive . I did not like the shift (manual) I made up a electric ( using good size electric door openers) works OK but if I were to do again I would use electric motors to shift. |
05-14-2015, 04:57 AM | #28 |
Has to be a strong motor to pull lever back and forth.Any pics
