09-13-2020, 04:46 PM | #1 |
1940 Ford Speedo Needle/Pointer Removal
I'm in the process of restoring the instrument panel from my 1940 3/4 ton pickup. How do I remove the speedometer needle/pointer so I can get the faceplate off?
Thank you in advance. |
09-13-2020, 07:12 PM | #2 |
Re: 1940 Ford Speedo Needle/Pointer Removal
It is simply pressed on to the shaft. However, I strongly advise against just prying it off. Rather, get a firm hold of the shaft with a needle nose plier and only then (gently) pry the needle off.
09-13-2020, 08:06 PM | #3 |
Perfect...I will give that a try. Thanks.
09-14-2020, 01:39 PM | #4 |
