Old 08-23-2012, 11:48 AM   #1
CaptDD
Default Throttle Linkage attached to Engine
First of all Hello!!! to the community. I am new here and am in the process of semi restoring a 31 Coupe.
With this Coupe I received some spare parts. One of the parts that I need to correct is the Throttle Linkage attached to the Engine. The one in the car was broken at the pedal end. There are no threads to attach a pedal. I did receive one as a spare which is broken at the drivers end and missing the linkage for the steering column control.
A few pictures to eliminate the 1000 word post;
http://www.captdd.com/ModelA/IMG_0321.JPG Full Size Image
http://www.captdd.com/ModelA/IMG_0322.JPG Full Size Image
http://www.captdd.com/ModelA/IMG_0323.JPG Full Size Image
I'm planning on removing the good throttle linkage from the broken bracket and placing it into the good bracket.
Question: Would the best method be to heat the end with the linkage ball and straighten it so that it will feed out of the bracket?
CaptDD is offline   Reply With Quote
