Old 03-12-2020, 03:42 PM   #1
usered
usered's Avatar
Default Coolant in the oil?
I have a 1939 v8 flathead that I had built several years ago. recently finally got to a point of starting it. Started fine went through a break in procedure. Several hours later I noticed coolant around some of the head bolts and spark plugs.
I restarted the motor warmed it up and re-torqued the head bolts. Same results coolant around the head bolts and plugs. It is now blowing smoke out the exhaust and when I checked the oil it appeared to be about 1/2 quart high. Oil was black not a milky color. Should mention I have Offenhauser heads on the motor.
Is it possible that coolant is leaking around the head bolts into the cylinders?
Any thoughts on what to check?
usered is offline   Reply With Quote
Old 03-12-2020, 03:48 PM   #2
JSeery
JSeery's Avatar
Default Re: Coolant in the oil?
Studs or bolts? Check and see which ones are leaking, they may not have been sealed. If it is blowing water vapor out the exhaust that is another issue.
Old 03-12-2020, 04:33 PM   #3
Ggmac
What radiator cap psi ? What head gaskets and any sealant under head bolt / nut flat washers ?
Old 03-12-2020, 04:35 PM   #4
deuce_roadster
deuce_roadster's Avatar
I always use sealant on the stud threads and for my initial run up start it with NO coolant in it and get it up to a temp where it feels too hot for my hand on the head and shut it off. Let sit overnight, Retorque, fire it up again, run it up to temp, shut off, let sit overnight, retorque.
After the 3rd cycle when cold after retorquing, I put the coolant in and then run it.
Aluminum heads should be torqued when cold, cast iron when hot.
Old 03-12-2020, 05:19 PM   #5
flatjack9
flatjack9's Avatar
Why hot for cast iron? I always let them cool also. Seems like they would grow when hot and shrink when cool thus affecting torque reading.
Old 03-12-2020, 05:25 PM   #6
usered
usered's Avatar
Thanks for the responses.
Using studs, smoke is much more then moisture in the exhaust. When you say sealant on the studs, all studs? What kind of sealant?
Its kind of hard to determine specific studs, seems to be the top ones leaking down to the low spots plugs etc.
Will have to check on radiator cap PSI, what should it be?
Old 03-12-2020, 05:49 PM   #7
Ggmac
Radiator cap 0 or up to 7 psi . Steel flat washers used with aluminum heads under nuts . Permatex works for me . I also spray the head gaskets with silver paint , couple of Coates , both sides . Always retorque 3 times after a warm / cold cycle . I also start without water till warm to the touch and shut off , retorque, repeat . Then add water . Of course when cold .
Old 03-12-2020, 06:14 PM   #8
philipswanson
Head (s) might be warped.
philipswanson is offline   Reply With Quote
Old 03-12-2020, 06:34 PM   #9
usered
usered's Avatar
Will try putting sealant on all the studs, use a flat washer and re-torque heads as suggested hot/cold three times without coolant.
Thanks
Old 03-12-2020, 07:15 PM   #10
JSeery
JSeery's Avatar
Torque values are cold. What are you torqueing the head nuts to?
Old 03-13-2020, 02:10 AM   #11
flatheadmurre
flatheadmurre's Avatar
If there is smoke from coolant coming out the exhaust now im not sure just tightening up the heads is the way to go now.
If you can get to the exhaust manifolds easily take them off and start up then you now what or if multiple ports you have smoke coming out of.
Then take heads of and start from there.
First find the problem...before starting to aply random bandaids...
flatheadmurre is online now   Reply With Quote
Old 03-13-2020, 02:25 AM   #12
Tinker
Tinker's Avatar
In a world were the head gasket seals tight. bolt leakage is annoying, but does not put coolant in the cylinder or crank case. Typically. Cycling the heads is good, but then Open it up. Leaky head studs are not what is going on. Maybe too much time on the head gasket? I don't think so... but I don't know.
Old 03-13-2020, 05:40 AM   #13
Ggmac
Thanks
Did you have the block tested before you rebuilt it ? Sorry if you already answered . What type of head gaskets ? Don't over torque!
Old 03-13-2020, 08:10 AM   #14
usered
usered's Avatar
Lots of good thoughts.
Couple of questions asked; the radiator cap is 7lbs., I torqued the head (aluminum) bolts to 40lbs. Not sure of what head gasket was used, I bought the motor completely assembled intake to pan. Had been assembled by a company in Dallas. I have all the specifications but doesn't indicate the gasket brand.
I think I will at this point I will remove the heads and try to see what's going on.
Thanks for the feed back.
Old 03-13-2020, 08:22 AM   #15
ct1932ford
ct1932ford's Avatar
May be a stupid question, but did you torque the heads in proper sequence?
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 03-13-2020, 12:42 PM   #16
Ggmac
Good luck and please keep use posted .
Gary
Old 03-13-2020, 07:57 PM   #17
Tinker
Tinker's Avatar
Good plan.
Old 03-13-2020, 08:51 PM   #18
rbone
May I ask which company in Dallas? Reason for the ask is that I am located just north of there and am looking for a rebuilder. Need to know who to stay away from.
rbone is offline   Reply With Quote
