Old 03-02-2020, 05:44 PM   #1
louieglen
Default Miles Per Gallon
What is the average MPG on the Model A's?
louieglen is offline   Reply With Quote
Old 03-02-2020, 05:50 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Miles Per Gallon
When I kept record I got 23 mpg at 55+mph over 1500 mile trip
Locally it gets 20 with mixed parade and regular driving--10$=about 100 miles
Old 03-02-2020, 06:00 PM   #3
Curtis in MA
I've never gotten more than 17.
Curtis in MA is online now   Reply With Quote
Old 03-02-2020, 06:44 PM   #4
Big hammer
Pull your plugs and if you see a tan color your good to go! After about 1 1/2 hours of driving Iam ready for a pit stop, driving in any car.
get a bigger hammer tap done
Old 03-02-2020, 06:59 PM   #5
Gold Digger
It sounds unbelievable but I got 24.4 once on a tour. I had just tuned it up and drove 45 to 50. Never got that before or after.
Gold Digger is offline   Reply With Quote
Old 03-02-2020, 07:04 PM   #6
GPierce
GPierce's Avatar
OK! Who is going to be next to top this?
GPierce is offline   Reply With Quote
Old 03-02-2020, 07:20 PM   #7
JOHN CT
JOHN CT's Avatar
Not me
Iíve tried different carburetors and plugs never got over 18 mpg.
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 03-02-2020, 07:21 PM   #8
holdover
15-20 depending on how many hills, always drive below 50 MPH
holdover is offline   Reply With Quote
Old 03-02-2020, 08:46 PM   #9
fundytides
Back in the day, a guy in our area used an A as his everyday, go to work, driver. It was in decent shape but well used and he averaged 25 miles to the Imperial gallon which equates to about 20 miles to the US gallon. A little less in the winter.
fundytides is offline   Reply With Quote
Old 03-02-2020, 08:47 PM   #10
BillEbob
BillEbob's Avatar
18 is about average for my Vicky, but then again we’re about a mile high here.
BillEbob is offline   Reply With Quote
Old 03-02-2020, 09:24 PM   #11
Synchro909
Synchro909's Avatar
I won our club's economy run a few years back with nearly 31 mpg.
Before you start saying "That's BS", we used to use the Imperial gallon.
I think that converts to about 25, maybe a little less to the US gallon.
If schools stay closed too long, parents will find a vaccine before the scientists.
Old 03-02-2020, 09:39 PM   #12
shew01
shew01's Avatar
My 1931 Victoria gets about 15 in the city and about 18 on the (non-Interstate) highway.
Old 03-02-2020, 09:55 PM   #13
DBrer
Depends on terrain and weather, but mostly around 18 mpg.
DBrer is offline   Reply With Quote
Old 03-03-2020, 07:59 AM   #14
Sunnybrook Farm
Sunnybrook Farm's Avatar
There was an article in the Restorer magazine probably in the 70s that showed a Ford report on mpg back in 1931 I think. Anyway it matches what people above are saying with most in the upper teens as I remember. Some were higher and some real low (probably leaking carb) anyway if you get in the low 20s then you are doing things right, just don't lean out and burn the valves. Of course we drive differently now, the state wide speed limit in Virginia back in 28 was 35 MPH unless other wise posted plus our engines are bored out and things have been done to get a little more speed.
Sunnybrook Farm is offline   Reply With Quote
Old 03-03-2020, 09:42 AM   #15
ryanheacox
ryanheacox's Avatar
If you get high teens-low 20s you should be good. I can do almost 20 in my Fordor on hilly roads. Not bad for the heaviest Model A they made.
Old 03-03-2020, 10:36 AM   #16
30 Closed Cab PU
I only get about 14 mpg max. Not sure why. Odometer calibrated, Fresh motor, tried different carbs including a rebuilt Berts, spark plug reads good, 3.54 rear end. 16 inch tires. Since it runs perfect, am living with it.
Old 03-03-2020, 12:50 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
The first rebuild of my engine when I first restored the car only got 15 mpg, only went 52 mph, when the rear main crumbled at 3000 miles I replaced the sunken valve seats, and replaced worn original cam with a "B"cam that showed little wear, ---same distributor,carburetor, manifolds , rods, pistons head, etc,--- made all the difference, top speed went to 67,fuel mileage went over 20
Old 03-03-2020, 03:53 PM   #18
barkleydave
barkleydave's Avatar
18mpg
barkleydave is offline   Reply With Quote
Old 03-03-2020, 04:40 PM   #19
Synchro909
Synchro909's Avatar
Another factor that influences economy which is not mentioned so far is gearing. My '28 Tudor has a 3.54 diff and Mitchell 26% O/D and B engine. The end result is not good. It is comfortable at 60 mph but even if I see an incline on the horizon, it slows down. Because the motor is lugging in O/D, it guzzles fuel. I have had it as low as 13 mpg - that is not much more than 10 miles per US gallon. I'm on the lookout for a standard gear set (3.78:1)
Old 03-03-2020, 10:19 PM   #20
Peyton
Over the past year 12.5 to 15.5 mpg. Car runs very well and is stock with no o/d. Drive 45 to 50 on tours. Engine is .100 overbore and operates in normal heat range.
Peyton is offline   Reply With Quote
