09-30-2013, 04:37 PM | #1 |
thermostat replacement
I had my radiator out of my 41 (stock 59ab), got it back in, cranked it up, ran fine, no leaks but then it started to smoke on one side. shut it down and the radiator boiled over. It was really hot, more on the one side then the other. I suspect a frozen thermostat. I don't know how to replace them. Could one or more of you gentlemen give me some ideas. thanks in advance. ricsvic
09-30-2013, 04:46 PM | #2 | |
Re: thermostat replacement
09-30-2013, 05:49 PM | #3 |
Here's a picture of how the thermostat should sit on the neck with the hose off. You can see the very thin wires I put through my thermostat and drape down the neck for the hose to clamp onto so that the thermostat doesn't get pushed up by the pumps, turn sideways, and quit working. Some just put an extra hose clamp above the thermostat to hold it down. That way is fine too if you don't care how it looks.
The thermostat shown is a Stant 14157 thermostat that I use. It is available on line many places including Amazon here: http://www.amazon.com/dp/B000C822YC or at NAPA part number THM 111, or at O'Reilly that sells the same stat as a Murray 4157, O'Reilly part number 2962. To learn why I use that thermostat read this thread: https://www.fordbarn.com/forum/showthread.php?t=113366 For more detail about installing the thin wires to hold the thermostat down go to this thread: https://www.fordbarn.com/forum/showthread.php?t=118305 and read my post #12.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 09-30-2013 at 07:19 PM. |
09-30-2013, 05:55 PM | #4 |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
