09-04-2019, 04:53 PM | #1 |
Harmonic balancer removal
How is the harmonic balancer removed from a 272 "Y" block. I have no tapped holes to mount the puller.
09-04-2019, 05:20 PM | #2 |
Re: Harmonic balancer removal
- deleted -
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 09-05-2019 at 07:08 PM. |
09-04-2019, 08:50 PM | #3 |
If the engine was a full-size car engine (not a T-bird), the crankshaft pulley does have two tapped holes for mounting of the add-on power-steering pulley. Cars that didn't have power assist did not have the pulley but they all had the two tapped holes for it. Anytime I have ever pulled my crankshaft damper, I just used a steering wheel puller. You made need to clean out the threaded holes in the damper with a tap-wire brush of the right size, and possibly run the proper size tap thru them.
Always put something round and flat between the end of the crankshaft and the center bolt on the puller so that that bolt doesn't bugger up the threads in the crankshaft for the damper center bolt. I have often used a short bolt of the same thread that the crankshaft damper center bolt is and screwed it in all the way. Using the bolt, you don't need to get a piece of rod stock and try to hold it in place while tightening the puller. |
09-05-2019, 12:29 PM | #4 |
