Old 03-12-2021, 06:37 PM   #1
JSRTUDOR
JSRTUDOR's Avatar
Default 1956 manual trans input shaft
Hi everyone. I have a 56 Mainline with the 3 speed manual trans. and 223 six. I recently dropped in a 272 and put a new clutch kit from Rock Auto on it. Is there any difference between a six cylinder car transmission and the v-8 car transmissions? Specifically the input shaft length and spline diameter? Thanks!
JSRTUDOR is offline   Reply With Quote
Old 03-12-2021, 09:39 PM   #2
darrell
Default Re: 1956 manual trans input shaft
not that i seen.
darrell is offline   Reply With Quote
Old 03-13-2021, 07:34 AM   #3
ponymare
What problems are you having?
ponymare is offline   Reply With Quote
Old 03-13-2021, 03:59 PM   #4
JSRTUDOR
JSRTUDOR's Avatar
Installed the engine and it went in too easy, and I have no engagement between the engine and transmission in gear, like the splines aren’t touching the clutch disc. I’m going to pull the engine again and check. I got an original bellhousing and went with an oem clutch kit.
Old 03-14-2021, 05:57 AM   #5
Mac VP
Mac VP's Avatar
Did that 272 possible come from a Ford truck? If you used the truck bell housing, which is about 1” deeper, the car transmission input shaft would probably fail to reach all the way into the clutch hub. Just throwing possibilities out there.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-14-2021, 06:25 AM   #6
darrell
.did you try the clutch on the shaft before you installed it.you dont need to pull the engine to fix this.
Old 03-14-2021, 06:57 AM   #7
flathead 53
Mac VP, is correct same thing happened to me , wanted to install A S-10 T-5 in my 53 f-100 , truck bell is about an inch to deep .
flathead 53 is offline   Reply With Quote
Old 03-14-2021, 07:13 AM   #8
ponymare
They might have given you a clutch disk for an older car, 1948 & back, or for pickup, much larger spline hole.
Old 03-14-2021, 01:06 PM   #9
KULTULZ
KULTULZ's Avatar
Post Re: 1956 manual trans input shaft
If swapping, you would first have to ID the TRANS TYPE and then match a disc to the input shaft and the plate to the flywheel. All same DIA of course.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 03-14-2021, 02:49 PM   #10
JSRTUDOR
JSRTUDOR's Avatar
Well it looks like my kit I got from rock auto has a 1 3/8 spline diameter and my input shaft is a 1". I have found a disc from NAPA that is a 10" disc, 10 spline, 1 1/16 diameter spline, I think it should work, 1/16 shouldn't cause an issue--right?
Old 03-14-2021, 11:51 PM   #11
dmsfrr
dmsfrr's Avatar
Only if you like watching clutch pieces fall out of the bellhousing
Find the right size replacement parts.
Old 03-15-2021, 04:28 PM   #12
Alaska Jim
Alaska Jim's Avatar
The splines on the clutch disc must matched the input shaft on the transmission. if you have no luck locating what you need, call Fort Wayne Clutch, Fort Wayne, Ind. , tell them what you have, they can, and will fix you up. https://fortwayneclutch.com/
Alaska Jim is offline   Reply With Quote
Old 03-15-2021, 08:42 PM   #13
JSRTUDOR
JSRTUDOR's Avatar
Thanks again everyone! Found one that is the correct size.
Old 03-16-2021, 03:43 PM   #14
KULTULZ
KULTULZ's Avatar
Here are two charts from the 1949/59 PASS CAR MPC that may be helpful -
- WHY IS IT ... -
Old 03-21-2021, 12:51 PM   #15
Lamar Wadsworth
Lamar Wadsworth's Avatar
1 1/16" is not close enough to 1" to work. Your clutch disc should engage the splines and move back and forth effortlessly, but it should not be loose. You shouldn't be able to wiggle it or move it up/down. Always test the disc on the input shaft splines before you put it together. You want effortless back and forth movement on the splines, but no slop.
Lamar Wadsworth is offline   Reply With Quote
