Old 01-04-2018, 10:24 PM   #1
hewe
Default T 5 transmission for ModelA
Where do I go for information on what I need to do to set up my T5 for the installation into my ModelA. Its from an S10, 2wd. Thanks
hewe is offline   Reply With Quote
Old 01-04-2018, 10:59 PM   #2
denis4x4
denis4x4's Avatar
Default Re: T 5 transmission for ModelA
Go over to the HAMB and do a search
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-05-2018, 04:31 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
https://www.fordbarn.com/forum/showthread.php?t=91507
https://www.fordbarn.com/forum/showthread.php?t=91594
https://www.fordbarn.com/forum/showthread.php?t=16475
http://www.lainefamily.com/ModelAFiles/ModelAT5.htm
Old 01-05-2018, 07:30 AM   #4
brokenspoke
I used a S10 5 speed from a 4x4 and kept the torque tube rear end....I got my information on the HAMB
brokenspoke is offline   Reply With Quote
Old 01-05-2018, 02:00 PM   #5
hardtimes
hardtimes's Avatar
I've heard so much information over the years, about different transmissions that can be used for Model A use. Why did you settle/select the year/model that you used ? I've heard to be careful to not get a transmission with wrong gear ratio, etc. So, what to look for on trans, a tag with id. ?
hardtimes is offline   Reply With Quote
Old 01-06-2018, 06:41 AM   #6
brokenspoke
Do a search on the HAMB "T-5 tech" lots of information
Old 01-06-2018, 02:01 PM   #7
Smog Tech
Smog Tech's Avatar
I installed a T5 in my 1930 Town Sedan. I wanted a low first gear for parades, and not too tall 5th gear because I didn't think my mostly stock engine could pull it. The T5 from 4 cyl. S-10 would be just about right, but I couldn't find one that I liked. So I got one from a S-10 V6, and changed my rear end to a 4:11. The result is perfect for what I wanted.
Smog Tech is offline   Reply With Quote
Old 01-06-2018, 07:11 PM   #8
tjw
tjw's Avatar
Model A alloy bell housing suit ChevyT5 Available LHD and RHD suit World class and non world class trans
tjw is offline   Reply With Quote
Old 01-06-2018, 10:36 PM   #9
Smog Tech
Smog Tech's Avatar
The MAC'S bell housing from Australia is what I used on my Model 'A".
Old 01-07-2018, 02:44 PM   #10
wensum
wensum's Avatar
A small technical correction from a kiwi, as there's a lot of competitiveness between New Zealand and Australia, the MAC'S bell housing originates from New Zealand, a couple of smallish Islands 1000 miles from Australia.
Also, whilst running an F150 gearbox in our A with a MAC's bell housing, I kinda wish it was a T5 S10. The F150 has proven ideal for fast touring but the 3 speeds proved limiting in a hill climb event
wensum is offline   Reply With Quote
Old 01-08-2018, 04:57 AM   #11
tjw
tjw's Avatar
Wensum
Just a small addition to add also. I am the official Mac's Speed agent in Australia and have been selling Graeme's NZ made products here and in the USA for a number of years now. I am also a born and bred " Kiwi " been here since 1988 but home is still New Zealand. Cheers
