06-25-2013, 08:17 PM | #1 |
Ammeter - charge/discharge
Just a quick question - While my '29 Model A Pick Up is idling, the ammeter sits around "0" and whilst driving it starts to move towards "charge" 20. However, when I switch my lights on it goes straight to "discharge" 20 and just sits there without moving towards charge or moving at all.
Anybody experience this before? - Your help is much appreciated.... |
06-25-2013, 08:36 PM | #2 |
Re: Ammeter - charge/discharge
Do you have stock headlights or have you installed higher power bulbs or halogen bulbs?
Do you have the stock generator? Are you still 6 volts?
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
06-25-2013, 08:43 PM | #3 | |
I have the stock headlights and have installed 32-50 candle power bulbs. Yes, generator is stock and I am still on 6 volts. Thanks Jim |
06-25-2013, 09:01 PM | #4 |
Repop meter or one of the old, good ones?
Meters new or old are notorious for being inaccurate. More so new. Your general direction on charge/discharge seem correct (it can be "0" if your generator charging is quite low and ignition use balances your generator output.) But that dramatic drop to more than 20 amp discharge seems a bit over the top. Do you have both high/low beams? Both filaments "on" at the same time might cause extreme current draw. Check that your wiring is not crossed between the low and high circuits. A cross/connect can cause BOTH filaments to be on with no discernible difference between high and low. Just throwing out ideas here of things to check. Joe K
Shudda kept the horse. |
06-25-2013, 09:31 PM | #5 | |
The Model A stock generator does not incorporate a voltage regulator. Voltage regulators came out a few years later and were a mechanical relay box bolted to the fire wall that monitored the battery status and the electrical load and adjusted accordingly and kept the battery fully charged. A Model A generator has a fixed amperage output. It is generally adjusted to a nominal 8 amps output. When driving during the day the ammeter shows plus, which means the generator is charging the battery. When driving at night the headlight load is more than the 8 amps the generator is putting out. The battery has to make up the difference. The ammeter will then show a discharge. The amount is depending on what size bulbs you have installed. The modern alternator has a built in solid state voltage regulator that constantly looks at the status of the battery and the electrical load requirement and adjusts the amperage output accordingly and keeps the battery fully charged. When alternators came out they were all 12 volts. Since then suppliers now sell alternators converted to 6-volt positive ground for the Model A. This is really the way to go if your Model A is a daily driver, though many purists frown on them. The alternator regulator circuit will monitor the battery and the electrical load and keep it fully charged regardless of the driving habits of the owner. In the old days it was common to see old cars on long stretches of highway with their headlights on during the day. This was done to drain off the excessive current the generator was putting out so it would not over charge the battery and boil the water out. people who drove their Model A's a lot at night always had a low battery that did not last them long unless they had a means to re-charge it during the day. Tom Endy |
06-25-2013, 09:44 PM | #6 |
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
06-25-2013, 10:52 PM | #7 | |
Tom, thank you for your very detailed information - you have been a great help! I am not too fussed about switching to a 6 volt alternator, I just want it to be more reliable. Basil |
06-25-2013, 11:25 PM | #8 |
One of the best kept secrets in the Model A hobby is Becker's Antique Auto Electric in Ohio. Larry Becker has been selling complete Model A 6-volt positive ground alternators for years at a bargain price. They come with a complete mounting kit and an extended warranty. Another plus is that his alternators are putting out current as soon as the engine is running at idle. You don't have to rev the engine to 1000 rpm for it to kick in like most others.
Tom Endy |
06-26-2013, 06:32 AM | #9 |
I get confused when I read stuff like this. The "problem" you state seems to be the amp meter or both filament's are coming on at the same time. How is an alternator going to help this? When someone states, " I just want it to be more reliable". More reliable then what? I have about 20,000 miles on mine, day night, rain, shine and the genny has never given me problems. The model A generator works just fine on the Model A. I even believe Model A's were used as everyday drivers with the stock generator in it's day.
Now, if you are going to add non stock items that draw more current then the original design, like halogen bulbs that give more un focused light in dull reflectors thus making one think it is safer to drive at night but really just blinding on coming cars, then an regulator or alternator is your best bet with a 30-0-30 ammeter. I've said it before if you properly fix what is not right on your vehicle then all you need is stock. If it makes an owner feels better to have these things on there car, then fine go and get them, but you do not NEED them. Want to have and need to have are two different things that often get confused on this forum.
06-26-2013, 06:40 AM | #10 |
20 amp charge from original generator is too high, 12-14 is about as high as you want to go. The 20 amp discharge has me thinking that maybe your headlight wiring is grounding/shorting itself at the connectors. To check to see if the ammeter is reading somewhat correctly, just step on the brake pedal and see what the stop light[s] are/is drawing. Depending on the CP of those bulbs it should be in the 6-8 amp range.
06-26-2013, 10:18 AM | #11 | |
Thanks for the REAL encouragement Mike V. Florida!!! I'm new to this forum and am just searching for answers, not people like you putting others down! |
06-26-2013, 10:20 AM | #12 | |
Thanks for your feedback Patrick L |
06-26-2013, 10:37 AM | #13 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
06-26-2013, 10:45 AM | #14 | |
Actually there are three voltage regulators available for the model A type generator. I use the Fun Projects can style voltage regulator. The Fun Projects regulator fits in place of the cutout and no modifications to the generator is necessary. The regulator looks like the early style cut out but functions like a modern voltage regulator. Fun Projects has a web site. I have used the Fun Projects regulators for years with good service. Try fun projects . com |
06-26-2013, 01:32 PM | #15 | |
I did not put you or anyone else down, if you want to spend money thinking an alternator is more reliable then a generator, go ahead buy it. I don't think an alternator will change your symptons. I think it is that both headlamp filiments are on at the same time or you have a bad ammeter. If trying to save someone money is putting them down well, we have a different idea of what a put down is.
06-26-2013, 03:11 PM | #16 |
Purdy,
With regard to the fun projects part; while it does regulate the voltage, it doesn't perform the regulation in the same manner as the old three/two unit voltage regulators. The fun product device uses a "shunt" type of voltage regulation while the older voltage regulators devices regulated by reducing the field current to maintain the output voltage constant. The fun projects circuit works, but in a different manner. Marc Last edited by marc hildebrant; 06-26-2013 at 05:23 PM. |
06-26-2013, 03:13 PM | #17 |
A Truck,
Mike V has given you some good information to think about. I suggest that you read the reply and take it as someone with experience trying to HELP you. Marc |
06-26-2013, 03:17 PM | #18 | |
2) James Peterson in the band P.O. Box 912 Bend, Oregon 97709 541-389-0438 home 3) Fun Projects
06-26-2013, 05:00 PM | #19 | |
Thanks, how it does it really makes no difference. The fact that it regulates the voltage, is simple to install and holds up well is all that matters to me. The Fun Projects regulator will work just as well for others as it has for me. They are available in six, eight and twelve volt versions and no mods to the original generator is needed, no matter which voltage is used. They can also be had in positive or negative ground version. I've been running our roadster twelve volt positive ground with the original generator for over seven years. One of the good things was , not a single wire had to be changed. The only way a person could know that it was running 12 volt would be if they saw the battery. Oh yeah, it ain't fun products, its Fun Projects. Big difference! |
06-26-2013, 05:25 PM | #20 |
Purdy,
Thanks for the correction. I'm not sure where I got products from ? Marc |
