Old 05-09-2021, 01:22 PM   #1
lynnm
Default Model A Transmission
I have a guy that is going to go thru my engine, now I'm looking for someone to rebuild the transmission for me. Would even purchase one if I could already rebuilt. I live just north of Indianapolis In, but willing to drive a little. Thanks
lynnm is offline   Reply With Quote
Old 05-09-2021, 01:39 PM   #2
HD Rider
Default Re: Model A Transmission
If I were spending your money, I would be tempted to get a Mitchel synchronized transmission.
If I'm spending mine, I'd rebuild it myself.
HD Rider is online now   Reply With Quote
Old 05-09-2021, 01:42 PM   #3
51504bat
51504bat's Avatar
Try Van Pelt Sales. They are located in Milford, OH, so not all that far from you. They are the go to source for many early Ford parts. Their web site says they do transmissions from 1928 to 1962.
http://www.vanpeltsales.com/FH_web/f...ans-repair.htm
VANPELT SALES LLC
1081 State Route 28 Bypass - Suite 258
Milford, Ohio 45150-2090
1-513-724-9486
Old 05-09-2021, 02:10 PM   #4
jayvee34
jayvee34's Avatar
Go to YouTube, There are video's of how a Model A transmission works, and video's of
how to disassemble, and rebuild them. If you have any mechanical ability at all, just follow the instructions and you can do it and have a feeling of accomplishment and gain a whole
lot of confidence.
John
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 05-09-2021, 02:13 PM   #5
larrys40
I can help if desired I am in St. Louis. I believe have a rebuilt on hand or I can do yours.
I do service and restoration work and Advertise in Model A News and Restorer.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 05-09-2021, 02:27 PM   #6
Tom Endy
Tom Endy's Avatar
Overhauling a Model A transmission is not difficult. You just need to be aware of the traps Henry laid for you. The attached link should be of help.
Tom Endy
https://www.santaanitaas.org/wp-cont...ugust-2018.pdf
Old 05-09-2021, 04:02 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Tom Endy
Another informative article, Tom. I used to have a helper like you. He's as tall as me now and interested in other things (girls! and computers!!).
Y-Blockhead
'30 Briggs Town Sedan
'55 Ford Ranchwagon
_________________________________
And once again that is just my 1 worth.
https://www.youtube.com/watch?v=51ufACHJMfU
Old 05-09-2021, 06:13 PM   #8
CarlG
CarlG's Avatar
I don't know about a complete rebuild, but back i n the day (I was 15 or 16 at the time) I took a Model A transmission apart, replaced a couple of gears that were broken and re-assembled it. Worked great. Bought the gears from NAPA.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-09-2021, 07:15 PM   #9
Mulletwagon
Mulletwagon's Avatar
Definitely entertain a Model A trans rebuild as a DIY project. Replacement parts are readily available and no special tools required to do the job. Do some homework, review a few Youtubes and you are good to go. Need to be aware of the continuing issue with replacement roller bearings and have a plan in advance. Much data on the topic on the forum. Good Luck.
Mulletwagon is offline   Reply With Quote
Old 05-10-2021, 08:54 AM   #10
rotorwrench
rotorwrench's Avatar
The A bone transmission is as simple as they get since there are no synchronizers in there. With the exception of some bearings, most parts are reproduced with decent quality. A person has to find the right people to supply new bearings since some of them are problematic.
Old 05-10-2021, 10:34 AM   #11
katy
katy's Avatar
Originally Posted by Mulletwagon View Post
Replacement parts are readily available and no special tools required to do the job. Good Luck.
One needs a special tool for redoing the transmission tower.
Play it again Sam.
Old 05-10-2021, 11:14 AM   #12
Ernie Vitucci
You might start with Brattons or Arizona Model A for your parts...Ernie in Arizona
Old 05-10-2021, 07:39 PM   #13
lynnm
Thanks everyone for your input, may go ahead and do it myself. Just want it done right so as not to have to pull it again, and as few leaks as possible. How do you know if the gears need to be replaced or not? Again thanks
Old 05-10-2021, 07:52 PM   #14
Y-Blockhead
George Bell has a 4 part series on youTube on rebuilding a Ford Model A Transmission. Has some good info... https://youtu.be/RPzUwu3Jf5Y
Y-Blockhead
'55 Ford Ranchwagon
Old 05-10-2021, 09:59 PM   #15
Harpkatt
I rebuilt a Model a Trans out of the back of my truck during a lunch brake at work. I was in a parking lot down the road. Easier than legos. I did not do the shift tower at the same time. It really is that easy.
Harpkatt is offline   Reply With Quote
Old 05-11-2021, 11:05 AM   #16
ryanheacox
ryanheacox's Avatar
I believe George Bell's video series goes into how the gears wear. Basically if the look good they probably are and if they look bad you can probably still use them if you don't drive much.
