Old 06-16-2021, 03:06 PM   #1
Alan O'Connell
Default Wiper arm tension 1936
Is there any way to lesson the tension on the wiper arm so it doesn't press against the windshield as hard?
Alan O'Connell is offline   Reply With Quote
Old 06-17-2021, 05:34 AM   #2
Ggmac
Default Re: Wiper arm tension 1936
Not sure if the 36 is different,but it all depends on the type of wiper arm . Some have a screw near the mounting point to the motor arm . The screw is attached to a spring to adjust the tension. Not all wiper arms have this .
Old 06-17-2021, 08:24 AM   #3
1931 flamingo
1931 flamingo's Avatar
Funny, most people want MORE tension...............
Paul in CT
Old 06-17-2021, 08:51 AM   #4
Jack E/NJ
Jack E/NJ's Avatar
Probably just feels like too much tension compared to modern longer wipers with a cam that allows them to pull & hold away from the windshield.
Old 06-17-2021, 09:07 AM   #5
51woodie
51woodie's Avatar
I have to ask if your wiper arms are original or aftermarket? The wipers and arms that were on my "46 Coupe when I bought it were aftermarket, and the arms were heavier with more tension then original and the blades were almost twice the weight of the originals. The wiper motor could hardly move the wipers. I replaced the arms and wipers with correct pieces, and the wipers work as they should.
51woodie is offline   Reply With Quote
Old 06-17-2021, 10:24 AM   #6
Alan O'Connell
It's an aftermarket wiper arm. The wiper motor works very slow. When I release a little tension by lifting the arm with my finger, the wiper motor works as it should.
Old 06-17-2021, 01:13 PM   #7
Lawson Cox
Lawson Cox's Avatar
Can you bend the arm slightly to relieve the tension?
Old 06-17-2021, 04:11 PM   #8
DavidG
DavidG's Avatar
Either switch back to original wiper arms or coat your windshield with RainX, which will lessen the drag of the blades.
Old 06-17-2021, 07:55 PM   #9
Alan O'Connell
I'll try RainX. I don't have original wiper arms.
Old 06-17-2021, 10:18 PM   #10
tomcarman
tomcarman's Avatar
X 2 with RainX. They also make a pre-application cleaner. Not convinced it's better than wash and windex first but the glass should be as clean as possible before applying.
tomcarman is offline   Reply With Quote
