Old 03-28-2018, 06:26 PM   #1
Rudolph
Rudolph's Avatar
Default Wasco timing fixture.
I made a video of the Wasco timing fixture, someone on here gave me the instructions. I fitted a Pertronics unit to my car and now I dont use this often,
https://www.youtube.com/watch?v=E2EE...ature=youtu.be
I found after fitting new points and a brand new cam and weights, new condenser the thing would run good for about 20 miles then need adjusting.
Rudolph is offline   Reply With Quote
Old 03-28-2018, 08:48 PM   #2
Brian
Brian's Avatar
Default Re: Wasco timing fixture.
Did you lube up the rubbing blocks and pivot points? I've found, once set up, these distributors run for thousands of trouble free miles. Sorry, I've never used electronic ignitions in a Ford, I wouldn't trust that stuff....
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-28-2018, 09:10 PM   #3
cas3
good one brian, i try to avoid those modern gizmos too
Old 03-28-2018, 09:15 PM   #4
Rudolph
Rudolph's Avatar
Yes I used distributor grease and I reoiled the wick inside the shaft, I started to get a hesitation under takeoff so I re timed it, then I drove 17 miles and the thing wouldn't start, I re timed it and it went for a rocket for about 10 miles then went funny.
After I fitted the Pertronox the thing was amazing, starts nearly instantly and has a strong idol, and will spin the wheels more easily, runs much smother, never had the thing off since
Old 03-29-2018, 06:49 AM   #5
Mart
Mart's Avatar
It sounds like the "new points" may have been an inferior product. Good quality points, lubed properly will last one hell of a lot longer than that.
I use points with a Velleman "Ignition amplifier" kit. It's an old school generation 1 electronic ignition that eliminates the condenser. The combo has proven very reliable for me.
Mart.
Old 03-29-2018, 11:39 AM   #6
coolcoupe
coolcoupe's Avatar
Hi Mart, what is a ignition amplifier ? Sounds like something I would like. Moe
coolcoupe is offline   Reply With Quote
Old 03-29-2018, 12:32 PM   #7
Mart
Mart's Avatar
Sorry for thread hi-jack..
Moe, this is the kit I use. You have to solder all the components onto the printed circuit board. I then put them in a little plastic box.
https://www.vellemanstore.com/en/vel...r-ignition-kit
Mart.
Old 03-30-2018, 02:15 AM   #8
Rudolph
Rudolph's Avatar
I used bob drake points and I have used used genuine points, brain suggested the Bosh condenser witch worked well, I did use Harley Davidson Sportster condensers to but they were more expensive.
I do like the pertronix unit, there is no way to tell its in there, distributor looks stock apart from condenser is gone, could even leave it in place.
Old 03-30-2018, 05:20 PM   #9
coolcoupe
coolcoupe's Avatar
Thanks Mart, but my 47 is all stock with 6v positive ground.It states it can not be used with positive ground. It sounded good thou. Moe
