Old 08-12-2013, 04:44 PM   #21
Hank
Hank's Avatar
Default Re: Babbitt or inserts
I have Babbitt, Schwalm's did the work. More than happy with what I have and will probably last longer than me. Just my 2 cents.
Hank
Hank is offline   Reply With Quote
Old 08-12-2013, 06:49 PM   #22
steve s
steve s's Avatar
If factory poured babbit were still an option, this would be a no brainer, BUT it's not and it never will be. My understanding is that the technology of getting a durable product is not trivial; some guy's garage operation--no matter how well intentioned and researched--may or may not be OK--it's a crap shoot. I've replaced enough bad rebuilds that I'm not interesting in unnecessary gambles.
Did you know that the actual bearing contact surface in inserts is Babbitt?
steve s is offline   Reply With Quote
Old 08-12-2013, 07:40 PM   #23
Ron W
Ron W's Avatar
I think you will find that the contact area on modern engine bearings is an alloy of aluminum. Ron W
Ron W is offline   Reply With Quote
Old 08-12-2013, 09:07 PM   #24
steve s
steve s's Avatar
Thanks for the update correction. It is true, isn't it, that for many years the shells were lined with Babbitt? The lore was that because this lining was so thin, it was essential to use an oil filter, since, unlike poured Babbitt, it could not embed small metal fragments out of harm's way.
Old 08-12-2013, 09:30 PM   #25
James Rogers
James Rogers's Avatar
Did you know that there is no contact surface in a Model A main bearing?
Old 08-13-2013, 08:54 AM   #26
steve s
steve s's Avatar
Jim,
I don't know what you mean.
Steve
Everyone,
Here's a segment from what Wikipedia has to say about Babbitt that may be of interest:
Modern Babbitt bearings[edit]
Until the mid-1950s, poured Babbitt bearings were common in automotive applications. The Babbitt was poured into the block or caps using a form. Tin-based Babbitts were used as they could stand up to the impact loads found on the connecting rods and crankshaft. The poured Babbitt bearings were kept thin. The rods and caps would have shims that could be peeled off as the Babbitt wore. Ford was known to use two .002" on each cap and Babbitt that was 86% tin, 7% copper, 7% antimony (see the KRW catalogs for the Model T). Steel shims were used as the brass shims used today tend to compress over time contributing to shorter bearing life. The poured Babbitt bearings commonly get over 50,000 miles of use before needing replacement. Poured Babbitt bearings are also known to fail gracefully allowing the car to be driven for extended periods of time. The failed bearing is not likely to damage the crankshaft.
In more modern practice, the crankshaft and connecting rod big end bearings in a modern automobile engine are made of a replaceable steel shell, keyed to the bearing caps. The inner surface of the steel shell is plated with a coating of bronze which is in turn coated with a thin layer of Babbitt metal as the bearing surface.
Old 08-13-2013, 11:51 AM   #27
Ron W
Ron W's Avatar
Jim may have mistakingly thought you ment metal to metal contact. Let's hope not too much! Certainly, there is contact with oil and possibly dirt or other crud that can cause some wear on the "contact" surfaces. BTW,I also use Inserts. Ron W
Old 08-13-2013, 12:51 PM   #28
Marklambert61
Marklambert61's Avatar
Like Henry made them!
KISS principle (Keep it simple stupid)
Mark
Marklambert61 is offline   Reply With Quote
Old 08-13-2013, 07:40 PM   #29
Ron W
Ron W's Avatar
Some may be interrested in this from Federal Mogal.
"The Future is Aluminum
Overplated copper-lead (“tri-metal”) has been the dominant engine bearing material for the past 20 years. But no longer. Over time, major domestic and overseas engine manufacturers have virtually eliminated it from their designs. And in the aftermarket, leading engine builders are phasing it out as well. The reason! A new breakthrough in engine bearing technology. Sealed Power A-Series engine bearings with aluminum-silicon bi-metal alloy. A-Series’ bi-metal alloy delivers greater seizure resistance than tri-metal materials, while dramatically reducing or eliminating bearing wear in a wide range of automotive and truck engines."
Ron W
Old 08-14-2013, 05:53 AM   #30
James Rogers
Jim,
Steve
Everyone,
Nothing here has anything to do with "contact Surface". The crank and bearing don't have any contact with each other except perhaps when the engine is at rest. Once the crank begins to turn immediately a hydraulic wedge is formed by the oil and any metal to metal contact is eliminated. Well kept bearings and oiling systems should last indefinitely.
BTW, Wikipedia is not the end all, be all. It is simply a place for people with opinions to have a voice and sometimes contains wrong or incomplete information.
Old 08-14-2013, 08:09 AM   #31
Frank Miller
Frank Miller's Avatar
Originally Posted by meskhov View Post
We use J and M Machine up in Mass exclusively for all our work, new and old alike. They are one of very few shops in the country that do metal stiching of cracks and do it properly. They have saved castings that no one else would have a chance at and I have seen several of them, wow!
They have done several Model A and T engines for us of which were Babbitt and one of these has almost 50 thousand miles on it and going strong. We check the clearances usually every 10-15k or so.
State of the art machinery that you won't find anywhere else in the entire country! Every time I visit them I never want to leave!
Take a look at their website, you will be impressed!
www.jandm-machine.com
Meskhov
As I understand it, Frank Casey of Millbury Ma does all their crack repairs. That is all he does. Makes all his own tooling. A real craftsman that may take some secrets of the trade with him.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 08-14-2013, 09:36 AM   #32
steve s
steve s's Avatar
OK, I now understand about "contact"; I'll be more careful in the future.
I agree that Wikipedia entries might simply be one person's opinion. But, I think there's a good chance that if something far out has been stated, attempts will have been made to either correct it or describe the controversy. I have found it to be pretty good in areas that I do know something about.
