09-17-2016, 02:53 PM | #1 |
Yankee ingenuity
Or farmer fix, or desperate times call for desperate measures.
Yesterday my wife and I were on our own on our way home from a three-day club tour, and as I came over a rise on a farm country road there was a large bang, a fiery flash, and a chuff-chuff-chuff sound as my power was significantly reduced. I first thought "head gasket", except the bang/flash didn't make sense for that. I coasted down the hill to a farmer's driveway and got off the road so I could safely assess the situation. When I opened the hood the problem was immediately evident: the #4 spark plug was gone. The spark plug connector was laying on the engine splash pan. I walked back up the road looking for the plug, but it was not to be found (a very nice fellow on a motorcycle stopped and walked the other side of the road with me, also looking). Going back to the car, I looked on the other engine splash pan, and there lay the plug, without its top nut. Hmmm. I called AAA, and they said they'd be there in 90 minutes to tow the car to the nearest town. I called a fellow club member who lived about 11 miles away and asked if he could bring me a spark plug, but then I realized all I needed to do was use the plug I had. All I needed was a nut, which I didn't have, or a piece of tape, which I also didn't have, or a piece of wire to hold the connector in place. I didn't have any wire, either. But I called my friend anyway, and told him I thought I could get it running without his driving 11 miles, and rummaged through stuff in the car looking for something to attach the connector. My wife noticed a brochure with a paper clip on it in the door pocket. Bingo! The answer. I called my friend and AAA and cancelled all requests for assistance. We made it into the nearest town (with intermittent missing), bought a new plug, and we were back on the road! You can keep a Model A running with a paper clip. See the attached photo.
09-17-2016, 03:04 PM | #2 |
Re: Yankee ingenuity
An office workers fix:-) a true farmer would have straighten the plug wire, with the tension to keep it on:-) at lease you did not loose it again!
09-17-2016, 03:41 PM | #3 |
Was it a 3x ?
09-17-2016, 03:47 PM | #4 |
I like that!
09-17-2016, 03:56 PM | #5 |
Ever figure out why it blew out anyway? Makes me curious.
09-17-2016, 04:28 PM | #6 |
Did you eat your Wheaties before you installed them Last edited by Mitch//pa; 09-17-2016 at 08:57 PM. |
09-17-2016, 04:44 PM | #7 |
Was thinking the same thing, what can cause that??
1930 Deluxe Coupe "Sister" |
09-17-2016, 04:57 PM | #8 |
If the threads weren't damaged, then it would seem the plug vibrated loose? I'm suprised you didn't noticed a little power loss as it was unthreading, assuming that's what happened.
09-17-2016, 05:05 PM | #9 |
Paper clips have many uses....
This one had been there for a while....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
09-17-2016, 05:37 PM | #10 |
I think it was the nut behind the steering wheel that caused the problem. When I put it back in on the road yesterday, I noticed that the threading got a little tight before it was fully seated. I am guessing when I originally installed these new plugs back in January I got to that tight spot and thought that plug was seated. So it was probably already loose, and finally just worked its way out. The new plug I installed yesterday did not have that kind of premature tightness. These are Autolite 3076 plugs; I think I'll get some Champion 3X.
09-17-2016, 05:51 PM | #11 |
Ray,
You mean you DON'T carry BALING WIRE & STRING?--tsk-tsk! Bill Prepared
09-17-2016, 05:57 PM | #12 | |
09-17-2016, 07:50 PM | #13 |
#4 was rebelling against that fancy coil wire.
09-17-2016, 08:04 PM | #14 |
Mitch, question....how much of a difference do the $25 or $30 plugs like the Champion 3X make versus a $5 plug
09-17-2016, 08:09 PM | #15 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Had this same thing happen on my 1994 Toyota Pickup truck with the 22RE 4-cylinder engine. According to the old mechanic guy neighbor after examining the aftermath . . . the plug blow out was my fault. When I'd popped in some new spark plugs, they were not properly tightened. Eventually, one of those plugs wiggled it's way completely unthreaded loose and . . . KA-BLAMMO!!! Out it blasted with a whistling rocket roar!
Well . . . . Duh! As I told him . . . there is no doubt that there must have been something wrong with that lousy wrench and socket. Explained to the wife that she needs to go out and buy me some nice new tools.
I wouldn't be so paranoid if people weren't plotting against me all the time Last edited by Capt Quahog; 09-17-2016 at 08:14 PM. |
09-17-2016, 08:26 PM | #16 |
I can't answer for Mitch, but I use the Champions in my coupe, and I honestly cannot tell the difference in performance between those and my sedan, which has the Autolites. But I like the look of the Champions more. (About $20 ea at O'Reilly's).
09-17-2016, 08:26 PM | #17 | |
The cost factor does not play into the equation for me. |
09-17-2016, 08:49 PM | #18 | |
Thanks
09-17-2016, 08:51 PM | #19 |
Read the reviews;;;
Champion Plug Type 3X (429) Copper Plus Spark Plug, Pack of 1 https://www.amazon.com/dp/B002796PJW..._YiF3xb0BS7F95 |
09-17-2016, 09:15 PM | #20 | |
