Old 12-01-2019, 06:07 PM   #1
fordwrencher
fordwrencher's Avatar
Default 1932-48 ford parts
City: salem
State: oregon
Price: in ad
Two 11-A-12127 ford helmet distributor cores....$65 ea....or $100. for both plus shipping.
51A-7503 clutch release equalizer, 01Y-7507 bracket and ball assy, and 01A-7545 spring for 1940-48 car and 1940-47 1/2 ton truck....$50....plus shipping.
ford flathead fuel pump 59-9350-A....$35....plus shipping. ships usps for $15.05
ford 1942-48 21A-3590B LHD pitman arm....$35....plus shipping. ships usps for $8.30
Steering mount bracket modified and powder coated to mount GM 122 manual, 525 manual, and 605 power steering boxes in stock location in 1941-48 chassis....$50....plus shipping. will ship usps flat rate
1938-48 ford license plate bracket....$10....plus shipping. ships usps for$8.30
Ford 11A-2454 1941-48 used brake and clutch pedal pads….$7....plus shipping. ships usps for $7.90.
New tie rod RH/LH ends with bungs for split wishbones....$40 pr....plus shipping. ships usps for $8.30
ford tie rod ends....$15....plus shipping. ships usps for $8.30
New ford 2 1/4" shackles. fits front or rear springs. Need to order bushings from Speedway #910-33325-1....$40....plus shipping. ships usps for $8.30
1935-37 18 tooth rear axles with spider gears. 32.8" long....$50....plus shipping.
New Offenhauser adj. 1-6-lbs fuel regulator #560-58500 for ford flathead.…$25....plus shipping. Ships USPS for $8.30
New motor/transmission mounts. 1937-48 car & pickup, and 1948-51 1/2 ton pickup....$15....plus shipping. Ships USPS for $7.90 sale pending
fordwrencher is offline   Reply With Quote
Old 04-06-2020, 03:18 PM   #2
fordwrencher
Default Re: 1937-48 ford parts
bttt
