Old 04-07-2019, 06:57 PM   #1
coolcoupe
coolcoupe's Avatar
Default battery
Are tractor supply 6 volt tractor batteries ok to use on our old cars?
coolcoupe is offline   Reply With Quote
Old 04-07-2019, 07:04 PM   #2
HDowse
HDowse's Avatar
Default Re: battery
If you buy the Group 1 it should fit and perform OK. I use NAPA Group 1 batteries in my old cars and get 7-8 years out of them. I’m careful to keep the water/acid leve topped off and charge them up once a month in the winter.
HDowse is offline   Reply With Quote
Old 04-07-2019, 07:27 PM   #3
coolcoupe
coolcoupe's Avatar
Default Re: battery
I 'm having a hard time getting a 6 volt battery lasting any more then 2 yrs so I heard about TSC and wondered if anyone had good/bad luck with them.
Thanks for the reply, Moe
Old 04-07-2019, 07:37 PM   #4
tubman
tubman's Avatar
Default Re: battery
Do they have any group 2 or 2L batteries? Group 1 batteries are kinda small and I've never had much luck with them. Chevies, Plymouths, and old tractors, maybe, but old Fords used a larger battery.
Old 04-07-2019, 08:02 PM   #5
Anteek29
Anteek29's Avatar
Default Re: battery
Recently got a Group 1 at our local Tractor Supply for my '55 Vic. Performs fine.
Less than $100. SKU # 132347299.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is online now   Reply With Quote
Old 04-07-2019, 08:39 PM   #6
4dFord/SC
4dFord/SC's Avatar
Default Re: battery
Last Monday, the local TSC had a clearance sale on 6v positive ground batteries.
4dFord/SC is offline   Reply With Quote
Old 04-08-2019, 08:59 AM   #7
totto
totto's Avatar
Default Re: battery
I went to "Batteries and Bulbs" and they have 6 volt for Ford Tractors and Model A. Bought battery for tractor. Price was reasonable.
totto is offline   Reply With Quote
Old 04-08-2019, 09:52 AM   #8
54vicky
54vicky's Avatar
Wink Re: battery
all batteries can be positive ground it depends on your battery orientation as to where the posts sitin relation to your cables(+ -)
54vicky is online now   Reply With Quote
Old 04-08-2019, 10:35 AM   #9
tubman
tubman's Avatar
Default Re: battery
Actually, there are "Positive" and "Negative" batteries. It has to do with the relative size of the posts.
Old 04-08-2019, 10:39 AM   #10
corvette8n
corvette8n's Avatar
Default Re: battery
Bought one for my Ford 8n there, it was in my tractor for about five years before I sold it, never had a problem with it.
Old 04-08-2019, 10:44 AM   #11
Bob C
Default Re: battery
Yes, the positive post is the larger one.
Bob
Old 04-08-2019, 11:09 AM   #12
Byron Warwick
Byron Warwick's Avatar
Default Re: battery
I have had Interstate 6v batteries since I returned to the road. One lasted 8 years, the next one only 2 years. i now am using an 8 volt Interstate, and find it is one of the best things I have done for my truck. You do not have to change any bulbs, and they are significantly brighter. It starts like a 12 volt battery. I started up the truck yesterday, after its winter hibernation, and never did anything thru the winter except to disconnect the ground cable.
Cheers, Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE !
Byron Warwick is offline   Reply With Quote
Old 04-08-2019, 11:56 AM   #13
mfirth
Default Re: battery
Always wondered about 8 volts, but don't know anyone here in Ohio running one. Any more of you guys using 8 v batteries? mike
mfirth is offline   Reply With Quote
Old 04-08-2019, 01:33 PM   #14
JSeery
JSeery's Avatar
Default Re: battery
You will find a lot of negative post on them if you do a search.
Old 04-08-2019, 04:58 PM   #15
rotorwrench
rotorwrench's Avatar
Default Re: battery
The 8-volt is not necessary if the electrical system is correct and in good condition.
Old 04-08-2019, 05:54 PM   #16
54vicky
54vicky's Avatar
Default Re: battery
that is what I said by writing orientation I guess I should have said size of posts but assumed that would be common sense they have been that way for at least 60 years and longer I only know of the ones I have owned ie big post+ negative-
Old 04-08-2019, 06:06 PM   #17
petes 50 merc
petes 50 merc's Avatar
Default Re: battery
i have a 6 volt optima in my merc my last one lasted over 10 years a friend of mine has one in his ford over 12 years
petes 50 merc is offline   Reply With Quote
Old 04-09-2019, 12:00 AM   #18
petehoovie
petehoovie's Avatar
Default Re: battery
You could try using AA's > https://www.youtube.com/watch?v=0k1tbf8muMc
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 04-09-2019, 12:15 AM   #19
40 Deluxe
Default Re: battery
Just remember, you must adjust the the voltage regulator up to a charging voltage of around 9.5 volts to keep that 8 volt battery charged or it will likely die an early death due to sulfation, plus it won't have the reserve capacity it should have.
Old 04-09-2019, 09:30 AM   #20
Dave Castle
Dave Castle's Avatar
Default Re: battery
1 question, 20 different answers, love it !
"If you do not want to hear the answer, don't ask the question!"
Dave Castle is offline   Reply With Quote
