Old 08-07-2018, 05:20 PM   #1
35ragtop
35ragtop's Avatar
Default Pertronix 1285LS Crab conversion
Hi Guys,
I am interested in reading more about these 1285LS conversion modules for the crab distributor. I searched on here and not much has been posted for a couple of years.
My set up is 12volt neg earth and alternator. Stock 59A .
There was some discussion about needing 1.5 ohm Coil and 1.5 ohm resistor, but some disagreed with the need for the resistor.
What is the latest suggestion for these units?
thanks,
Dave
35ragtop is online now   Reply With Quote
Old 08-07-2018, 06:50 PM   #2
bobscogin
Default Re: Pertronix 1285LS Crab conversion
What does Pertronix specify?
Bob
bobscogin is offline   Reply With Quote
Old 08-08-2018, 10:13 AM   #3
Kahuna
Kahuna's Avatar
Pertronix recommends full 12 volts to the Pertronix trigger unit.
Use a 1.5 ohm 12 volt coil.
Kahuna is offline   Reply With Quote
Old 08-08-2018, 10:42 AM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Yep ,and i would suggest using a NAPA IC12SB coil.........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
jimlinder@juno.com
BUBBAS IGNITION is offline   Reply With Quote
Old 08-08-2018, 03:35 PM   #5
35ragtop
35ragtop's Avatar
Great thanks guys,
some of the earlier posts were misleading (back in 2013). It appears to be an easy conversion.
Dave h
Old 08-08-2018, 06:55 PM   #6
Gary in La.
Gary in La.'s Avatar
Check for excessive wear in the bushings. The original shops that did these conversions (Jerry Jobe & Mickey Remund) would install new bushings and line ream them. I suspect that's why these units didn't have a lot of the problems that later do it your self ones had.
Gary in La. is offline   Reply With Quote
