05-30-2010, 01:13 PM | #1 |
Ammeter At Zero
The ammeter in my Special Coupe shows no charge. I have an alternator on 6 volt system and need a hint at where I should start looking. Thanks for any suggestions.
05-30-2010, 01:27 PM | #2 |
Re: Ammeter At Zero
check the amp meter . pull the dash panel & see if you have voltage there . you can check the alt at the hot post to see if its working .................... steve
V4f |
05-30-2010, 02:16 PM | #3 |
Re: Ammeter At Zero
im going to yelled and told im an idiot, but have been told that before, i dont know what alt you are using , an external regulator or an internal regulated one but doesnt really matter, start engine and remove the ground from batt or at the engine, which ever one is easiest, if engine keeps running the alt is ok, if it dies the regulator is bad, run it with out the ground just long enough to see if engine dies then turn off key and put ground back on, this is just a quick emergency test, ok lol let the insults begin lol
05-30-2010, 03:55 PM | #4 |
Re: Ammeter At Zero
If the engine is NOT running and you turn on the headlights, does the ammeter show a DISCHARGE? It should.
If it does, that will rule out a faulty ammeter. Also check where the wires connect to the alternator. I have seen them vibrate loose and fall off. Then after that, I would say you have a bad alternator.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
05-30-2010, 04:06 PM | #5 |
Re: Ammeter At Zero
Listen to Jim/TX regarding how easy it is to just look at the amp meter with the lights on or blow the horn to see if shows discharge.
If so, the amp meter probably works. DO NOT DISCOUNT BAD WIRES or connections. Before you dump the amp meter check input and output with a volt meter to each side. Put it "In Line" between the IN and OUT at the terminal block (using 14-16 gauge jumpers) and see how it reacts with a load put on it by lights or horn. Oh yes, running your alternator with no battery will cost you a trip to the alternator shop. |
05-30-2010, 04:49 PM | #6 |
Re: Ammeter At Zero
05-30-2010, 05:35 PM | #7 |
Re: Ammeter At Zero
Does it show any discharge like Jim/tx asked?
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 05-31-2010 at 12:22 AM. |
05-30-2010, 06:04 PM | #8 |
Re: Ammeter At Zero
Ray,
Do you mean it show's no charge all the time?.. i have a 6 volt alternator system also and when i start it up the amp. meter will go to aprox. plus 5-7 for about 30-40 sec. then drop back to 0 amp's and stay there untill i shut it off and start it agin. i'v had the car about a year now and no problem's with the batt. at all. |
05-30-2010, 08:20 PM | #9 |
Re: Ammeter At Zero
I had a bad cell in my battery about a year ago and my amp meter would not show a charge. When I would rev up the engine or go down the road it would show no charge. When I put a new battery in and go down the road, the amp meter shows a charge. Have the battery checked.
05-30-2010, 08:45 PM | #10 |
Re: Ammeter At Zero
check you condenser . Might be going bad. Does the car start well?
