04-03-2013, 02:35 PM | #1 |
Source for good points cams?
I was going through the ignition system on my S/W and while checking points gap, rotated the cam lobe to check timing, but decided to verify the gap just one more time before I set the timing, I noticed that when I re checked it the gap went from .018" to .024", I thought that cant be, so for the heck of it I checked every lobe and to my surprise they all varied from .016 to.024. This cam came with a rebuilt distributor from a well known parts house, which is disappointing needless to say.
Does anyone have a source for good points cams that dont vary so much?
1931 Slant Windshield fordor |
04-03-2013, 02:46 PM | #2 |
Re: Source for good points cams?
Interesting. Could one be easily machined?
04-03-2013, 02:53 PM | #3 |
04-03-2013, 03:00 PM | #4 |
Bill Stipe's distributor cams are the best ones made.
04-03-2013, 03:05 PM | #5 |
Stipe Machine makes the best distributor cam. This part has 10 more degrees of dwell for a hotter spark. Call 920-467-2895 ask for A-B cam ,part number SMC 0033 . The last that I heard the price was only $12.75
04-03-2013, 03:31 PM | #6 |
04-03-2013, 04:21 PM | #7 |
As well as consistent point opening gap, you also want the points to start oepning exactly 90* apart. I have checked both on my homebuilt distributor tester and haven't had a problem with Bratton's cams, which are the "B" cam with 10 more degrees dwell, and as far as I know these are the only cams being made today.
I have also bought cams from Bert's and found the same good quality. I haven't bought any cams for the past few years, so hopefully the quality still remains. |
04-03-2013, 04:42 PM | #8 | |
04-03-2013, 04:45 PM | #9 |
04-03-2013, 05:02 PM | #10 | |
04-03-2013, 06:00 PM | #11 |
i think thats his old website
04-03-2013, 06:41 PM | #12 | |
04-03-2013, 06:42 PM | #13 | |
04-03-2013, 06:52 PM | #14 |
Bill Stipes website is now http://www.specialtymotorcams.com/
Also, if your points gap varies, check your distributor shaft bushes for wear. When I first got my Tudor, it ran rough. I checked the points and set them to .020". It wouldn't start afterwards. As I was checking other things, my dad rechecked the points and found them closed. We found we could open and close the points just by wobbling the shaft. |
04-03-2013, 06:59 PM | #15 |
Like Ken, I would check elsewhere first, as I've never heard of a cam having lobes that far out of spec. Also make sure the upper plate doesn't have side play. Between worn dist. bushings and a loose upper plate you can vary the points gap quite a bit.
04-03-2013, 07:14 PM | #16 |
Its definitly the cam, I swapped it out with a known good original cam from one of my junk distributors and bingo, .018, .018, .018, .018
04-03-2013, 07:20 PM | #17 |
I'd send back the cam and ask for a new one. Something's really wrong with one that far out, and I'm sure the dealer would like to know about it.
04-03-2013, 07:25 PM | #18 | |
Is the cam that Snyder's sells a B cam?
04-03-2013, 07:48 PM | #19 |
Sorry Christian,i thought you were refering to a V8 dist. My mistake. ken ct.
04-03-2013, 08:07 PM | #20 | |
Once you get on that page, there are buttons on the left side of the page. Hover over thim off to the side a bit, not directly on the words themselves. Your cursor should turn to the perverbial finger. Click on it then and it should take you to the page you are pointing at. He does have 2 sites, don't remember the other one.
