07-05-2018, 09:37 AM | #1 |
Trade 1952 F1 for Mode A+cash
City:
Marana
State:
AZ
Price:
22,000
Ready to sell or trade my sweet 52 F1 with a/c for a driveable Model A plus cash.
RECENT MODIFCATIONS: 2015 New Ivory Acrylic Urethane paint. The original flatbed, which was all framed in wood was replaced with a custom built 2x4 metal tubing frame. Both the bed, sideboards and running boards were all redone in redwood and new metal bed strips were installed. All the wood received six coats of Cabot’s Satin Spar Varnish. New pistons were added in June 2016, new clutch, pressure plate and TO bearing in 2017 ENGINE 180 Degree Thermostats, Modern One-Piece Front Oil Seal, New Pistons & Rings, Rod, Main and Cam bearings. Hollow adjustable Johnson style lifters, Howard M-6 ¾ cam, Valves, Valve Guides, Springs and Clips, Graphite Head Gaskets, Full Flow Oil Filtering System, Melling Type High Volume Oil Pump, GM Distributor from Bubba's Speed Shop, 2700CFM, Hurricane Air Conditioning Package, Thermostatically Controlled 12-volt Ice Box Cooling Fan System. FUEL SYSTEM Offenhouser dual intake, Dual Holly 94 Carburetors Rebuilt by Go Cats Speed Shop, Electric Fuel Pump, Fuel Pressure Regulator, 14 Gallon Gas Tank Installed Under Bed with Pop-Up Gas Filler. ENGINE COMPARTMENT New Water Pumps, Speedometer Cable & Drive Gear, Hedman Turbo Mufflers, Red's Headers, Custom Tail Pipes, Radiator Recovery Tank, New Radiator, and New 12-volt Battery. ELECTRICAL Ron Francis Express 21 circuit 12 Volt Wiring System, 100-amp Single Wire Alternator, Ignition Switch, Push Button Turn Signals, Under Hood Light, Dome and Under Dash Interior Lighting, Battery & Ground Cables, Parking Light Assemblies, 12 Volt Windshield Wipers from New Port Engineering, Tail Lights, Voltage reducer for using stock fuel & Amp. gauges, Dual Temp Gauges, Oil Pressure Gauge, Boss 200 Watt CD/Radio Combo, 6x9 Dual Voice Speaker, (2) Tweeters in door posts. BRAKES & SUSPENSION Tie Rod Tube and Ends, Spindle Bolts, Steering Stabilizer, Front Wheel Bearings, All Wheel Cylinders, All Brake Shoes, Rebuilt Master Cylinder, Shocks, Rear Leaf Spring Shackles, Bolts and Pins, Spring Bushings. INTERIOR Total Cab Sound Dampening Insulation, carpet, Headliner & Cab Panel Kit, Velour Bench Seat Cover Kit, DOORS, GLASS & BODY Door Glass Runs, (1) Window Regulator, (1) Door and Rear Window Glass, All Glass and Cowl Vent Seals, Vent Window Locks, Armrests, (3) Seat Belts, Polished Aluminum Ford Step Plates, Custom 2x4 Steel Tubing Flat Bed, Redwood Bed, Running Boards and Side Boards, Metal Bed Strips. SERIOUS INQUIRIES ONLY - NO SOLICITORS If interested PM me or call Richard (520) 407-6075 Last edited by chap52; 07-31-2018 at 07:01 PM. Reason: added info |
07-31-2018, 07:04 PM | #2 |
Re: Trade 1952 F1 for Mode A+cash
Btt
08-29-2018, 06:57 AM | #3 |
Btt
10-10-2018, 04:34 PM | #4 |
