Old 06-20-2013, 06:07 PM   #1
Duffy1
Default Running engine at 800-900 rpm in neutral
I was informed by one of our club model A gurus that it was not good to rev the engine up in neutral. He said you need to have the engine under load when running higher rpms. Appreciate your input .Thanks
Duffy1 is offline   Reply With Quote
Old 06-20-2013, 06:13 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Running engine at 800-900 rpm in neutral
Someone says that you can't run the engine at 900 RPMs in neutral. Really. I think someone is pulling someones leg, I'll let you determine which one.
Old 06-20-2013, 07:57 PM   #3
1931 flamingo
1931 flamingo's Avatar
Did he happen to say why?? You can't believe everything someone tells you, but if it's on the internet it has to be true (chuckle, chuckle).
Paul in CT
Old 06-20-2013, 08:18 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
1000 RPM is OK, but other than a quick blip of the throttle I don't like to go high revs in neutral. When the engine is under load it's compressing more air, which helps to cushion the sudden direction change of the piston at the end of the stroke.
Old 06-20-2013, 08:34 PM   #5
Jordan
Jordan's Avatar
I would think it would be better to run it at a fast idle than a slow idle.
Cowtown A's
Jordan is offline   Reply With Quote
Old 06-20-2013, 08:56 PM   #6
700rpm
700rpm's Avatar
Why would you want to do that for any length of time?
Ray Horton, Portland, OR
Old 06-20-2013, 09:16 PM   #7
Bill Steiner
Does not make sense. I can see no reason this can do any harm. Bill
Bill Steiner is offline   Reply With Quote
Old 06-20-2013, 09:20 PM   #8
Duffy1
I need to charge my AC which requires the engine to turn about 800 - 900 rpm before the compressor starts working .
Tom ; Thanks for the informative response .
Old 06-20-2013, 09:22 PM   #9
160B
160B's Avatar
Paul in CT
State of disbelief, you can't put anything on the internet that isn’t true; I know I heard it on the internet!!!
https://www.youtube.com/watch?v=rmx4twCK3_I
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-21-2013, 06:03 AM   #10
Jim/GA
Jim/GA's Avatar
Won't hurt a thing.
Jim Cannon
"Have a Model A day!"
Old 06-21-2013, 06:33 AM   #11
Mitch//pa
has others have said maybe the guru bumped his head
Old 06-21-2013, 10:34 AM   #12
CarlG
CarlG's Avatar
I wouldn't call 800-900 rpm "Reving-it-up". 1500-2000 would be!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-21-2013, 10:39 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
800-900 RPM would just be a fast idle. Some performance cams need to idle at that rate.
Old 06-21-2013, 10:48 AM   #14
MrTube
MrTube's Avatar
Both of my 2012 cars idle at 750rpm. Before anyone attacks modern engines, these little 1.4 liter engines peak torque at 1700rpm and hold it to 5500rpm so I wouldn't say they are bad.
Anyway, my feelings are the model A's engine could run at 1000rpm 24\7 with no load on it with a little timing advance and the proper fuel mixture.
MrTube is offline   Reply With Quote
Old 06-21-2013, 02:28 PM   #15
modelAtony
modelAtony's Avatar
My engine builder of inserted engine told me to button it up, crank it , if no leaks idle up to 1400 rpm and let it run for 10 hrs while keeping a close watch on it . His directions to me were after that, it is now fully broke in . Fooled me but he was correct. Pushing on 55,000 miles in 4 years have fun modelAtony Lafayette, LA
modelAtony is offline   Reply With Quote
Old 06-21-2013, 04:19 PM   #16
Mad Mac
After I had my stock engine reconditioned professionally I imagined I heard a bearing knock so I took it back to the reconditioner. After listening to it for a while at slow speed in neutral he increased it to maximum revs and held it there for about 10 seconds. I was horrified and thought he was ruining a new engine by doing that. He then looked at me and said "Nope, nothing wrong there". That was about 20,000 miles ago and she is still going strong.
Mad Mac is offline   Reply With Quote
Old 06-21-2013, 05:03 PM   #17
ctlikon0712
ctlikon0712's Avatar
"The thing about quotes on the internet is that you cannot confirm their validity."
Abraham Lincoln
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 06-22-2013, 10:16 PM   #18
40 Deluxe
Two questions about the "cushion of air" theory: What about when you're running say 40 or 50 MPH and back off the throttle to slow down? You're at high revs with suddenly no load on the engine, and you do this dozens of times on every trip!
Next, what about the exhaust stroke? On every other revolution of the crankshaft, your pistons are coming up to top dead center and suddenly changing direction without the benefit of any "cushioning" effect!
40 Deluxe is online now   Reply With Quote
