11-01-2017, 12:43 PM | #1 |
flat head oil question
I recently obtained a 1947 mercury with a flathead v8. I would like to change the oil and filter.
what is the recommended oil to use in a flathead v8? and filter? not sure what oil is in there now |
11-01-2017, 03:30 PM | #2 |
Re: flat head oil question
11-01-2017, 03:43 PM | #3 |
There are more opinions on this subject then I care to list (I highly recommend searching for multiple previous conversations on this subject.) Some say non detergent single weight, others modern multi-weight. Universal opinion to avoid synthetics. In my lincoln I use 10w-30 because that's what the previous owner used.
11-01-2017, 03:52 PM | #4 |
Food for thought, open this link.
https://www.fordbarn.com/forum/showthread.php?t=231478 As Zephyr Q says, do a search. You can read for hours. |
11-01-2017, 04:41 PM | #5 |
We have used Castrol 20W-50 for many years. Avoid non detergent and synthetic oils. Non detergent oils are obsolete, and will allow sludge formation. Synthetics are fine oils, but tend to leak badly in old Fords, even more than usual. Conventional oils cost much less, allowing frequent changes. Use a good brand of oil. and don't waste money on additives.
11-01-2017, 04:57 PM | #6 |
11-01-2017, 10:38 PM | #7 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
11-01-2017, 10:54 PM | #8 |
Doesn't matter all modern oils are way better than anything used back in the day.
But 10/30 detergent seems to win out alot. |
11-02-2017, 12:03 AM | #9 |
Like Mr. Sisson....15/40 Delo or Rotella...
Whether you think that you can,or that you can't,you are usually right....H.Ford |
11-02-2017, 04:17 AM | #10 |
In the absence of any history on your engine, ie recently fully rebuilt or never rebuilt or uses a bit of oil or whatever. I would not use a detergent oil if its not a newly rebuilt engine or a synthetic oil at all. I use a good solid oil like 20W/50 or similar. I use Penrite HPR 30 in all my old V8s. You may not find that in your area. Castrol 20W/50 would be another very good choice. There have been hundreds of posts on this question and half as many different answers. Don't be conned into high tech high performance ultra modern oils because your old flathead does not require them. Don't use any additives either. Good luck with your new Mercury. Regards, Kevin.
11-02-2017, 10:22 AM | #11 | |
Thread Tools | |
Display Modes | |
