Old 11-01-2018, 10:49 AM   #1
1930artdeco
1930artdeco's Avatar
Default dist. wire-lower plate
Hi All,
One of my winter projects is to build up a stock distributor. My question is the lower plate wire-can it be/should it be-heat shrunk to protect it from shorting against the body? I have not done this yet I am just thinking ahead and planning.
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-01-2018, 11:03 AM   #2
Bob C
Default Re: dist. wire-lower plate
Take a look at Vince's site for his solution to the wire problem.
http://www.fordgarage.com/pages/adistlowerplate.htm
Bob
Old 11-01-2018, 11:11 AM   #3
1930artdeco
Thanks Bob, that answers my question. Does anyone know what screw size the little screws that hold the lower plate down are?
Mike
1957 Country Sedan
Old 11-01-2018, 12:10 PM   #4
Bob C
From the parts book 8-32x1/4" round head
Old 11-01-2018, 12:59 PM   #5
1930artdeco
Thanks again Bob.
Mike
1957 Country Sedan
Old 11-01-2018, 10:11 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
I don't know if there is any hobby shops left but if there is one near you get the silicons covered wires used for R/C car battery packs. Along these lines, https://www.amazon.com/12-Gauge-Sili.../dp/B0070RZXLW
Old 11-02-2018, 09:49 AM   #7
katy
katy's Avatar
If you use heat shrink over the wire it will be too stiff.
Test lead wire such as used on good, not cheapies, multi meters is nice and flexible and sturdy enough.
Old 11-02-2018, 10:29 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
The parts houses sell a nice flexible wire for the lower plate.
Bert's, Bratton's, and Snyder's are a few.
Old 11-02-2018, 01:22 PM   #9
Patrick L.
Patrick L.'s Avatar
Hmm, must be Vince is still mad. He still doesn't post and he always has some good info.
Old 11-02-2018, 02:21 PM   #10
1930artdeco
I have a bunch of parts already but I don't remember if I have the covered lower wire or not. I will dig into it after I finish rebuilding my stove clock. Thanks for the replies.
Mike
1957 Country Sedan
Old 11-02-2018, 07:03 PM   #11
Tom Wesenberg
Vince is one of the GOOD guys that were banned last year.
Old 11-05-2018, 06:49 PM   #12
1930artdeco
Ok I went and looked and my stash of parts and only need the three lower plate screws and the wire. Here is the lower plate I have is it still good to use? I thought they were supposed to be nicely curved not 'bent'.
Mike
1957 Country Sedan
Old 11-06-2018, 02:38 AM   #13
Tom Wesenberg
Mike
Those look good. Here's a picture of mine.
Old 11-06-2018, 06:34 AM   #14
bigd1101
bigd1101's Avatar
Can one build a zipper distributor cheaper than the $400+ ones selling on various sights?
bigd1101 is offline   Reply With Quote
Old 11-06-2018, 10:00 AM   #15
1930artdeco
Thanks Tom,
Just need to find the wire and get a few screws and I will be in business.
Mike
1957 Country Sedan
Old 10-29-2020, 03:59 PM   #16
walkerlakeprinter
walkerlakeprinter's Avatar
I am working on an old distributor and I installed a new lower plate from Snyders with the longer wire. I need to know if I have mounted the wire to the original upper plate correcctly. The lug held on by the nut seems likely to contact the body if it shifts even a little bit. Should I do something more to insulate it further? See attached photos.
walkerlakeprinter is offline   Reply With Quote
Old 10-29-2020, 05:09 PM   #17
Bob C
This is how it should look.
Old 10-29-2020, 06:57 PM   #18
Bruce of MN
Bruce of MN's Avatar
OT, but I superglued that insulating washer to the bus to make installing the condenser easier.
Old 10-29-2020, 09:49 PM   #19
redmodelt
redmodelt's Avatar
Look at eBay for kits. I can even buy them for my 1920 Dodge. Cost depends on if you get the coil or not.
https://www.ebay.com/sch/i.html?_fro...ition&_sacat=0
Old 10-29-2020, 11:19 PM   #20
CWPASADENA
CWPASADENA's Avatar
I have been using the good quality test lead wire for many years on a lot of distributors with very good results. I would not also use shrink tube as I feel the wire should be as flexible as possible.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
