10-20-2012, 10:29 AM | #1 |
Shocks
Should shocks need adjustment from time to time or just add fluid? Car has rebuilt shocks couple of years ago but seems to be getting a bit bouncy.
Thanks, Steve |
10-20-2012, 10:57 AM | #2 |
Re: Shocks
How often do you drive your car, could be flat spots on your tires from sitting.
10-20-2012, 11:15 AM | #3 |
Re: Shocks
I drive the car every day, 10-12k per year....
10-20-2012, 11:55 AM | #4 |
Re: Shocks
probably not your tires Wish i could drive mine daily....your coupe looks really good, color and black tires and rims...
10-20-2012, 12:24 PM | #5 |
Re: Shocks
Yes shocks are adjustable and dependent upon "warm" or "cold" weather driving. No doubt it relates to the effect ambient temperature has on the shock fluid viscosity. Les Andrews manual has shock adjustent details. Makes a very noticeable difference when they are adjusted properly. If your shocks are only two years old I would not think they would be leaking fluid.
10-20-2012, 12:30 PM | #6 |
Re: Shocks
10-20-2012, 01:05 PM | #7 |
Registered User
Re: Shocks
depends where they are leaking from
i have the most problem with them leaking through the cover threads if they are leaking around the shaft then its the shaft seal |
