02-09-2018, 08:03 PM | #1 |
Starter shim
Does anyone know if a metal shim starter shim is available instead of the .010 paper type?
02-09-2018, 09:47 PM | #2 |
Re: Starter shim
Are you using the ABELL drive?
That's the only one that used shims. |
02-11-2018, 07:12 PM | #3 |
Re: Starter shim
Just stock starter and a standard bendix
02-11-2018, 07:18 PM | #4 |
Re: Starter shim
Having trouble every now and then with a stuck starter, I've filled any burrs off the ring gear. I sometimes can start and drive for months without any problem, then it then it sticks again. I've got a paper shim in now and I'm down to my last one in stock. Would like to try a metal shim to see if that will work a bit better.
02-11-2018, 07:53 PM | #5 |
Re: Starter shim
Where are you placing the shim?
Is the drive staying engaged due to a sticking starter switch? |
02-11-2018, 08:51 PM | #6 |
Re: Starter shim
02-11-2018, 09:03 PM | #7 |
Re: Starter shim
Are you sure your shaft is straight.?
02-11-2018, 09:15 PM | #8 |
Re: Starter shim
I second Tom's question. Shims are supposed to be needed only with the very earliest style (ABELL) starters. I think you may be grasping at the wrong straw. If the problem occurs as rarely as you indicate, it's going to take a century of data to establish statistical probability.
02-12-2018, 02:20 AM | #9 |
Re: Starter shim
Shims will only make the problem worse by shifting the drive closer to the flywheel.
Check that the drive helix is clean and has nothing heavier than a thin coat of very light oil. Also make sure the tiny pin and spring on the pinion is free to move and has a drop of oil for easy movement. |
02-12-2018, 06:10 AM | #10 |
Re: Starter shim
The reason your starter is sticking is the shaft is slightly bent and the teeth on the flywheel are worn in one place. You would be smart to replace the starter and the next time the flywheel is exposed, replace the starter ring.
http://www.model-a-ford-4bangers.com/ |
