01-31-2019, 10:11 AM | #1 |
1957 Ford Thunderbird Supercharged Fuelpump
My friend has a supercharged 57 motor and needs to know if it used a different fuel pump and if so what is the correct number. Where could he purchase one?
01-31-2019, 11:29 AM | #2 |
Re: 1957 Ford Thunderbird Supercharged Fuelpump
The Supercharged machines did use a special fuel pump.
Its Ford part# B7A9350-A. Gonna be tough to find. Try all of the T Bird venders. I would suggest having the one he has rebuilt. Oldmics |
01-31-2019, 01:58 PM | #3 |
They also had a special fuel filter, with a return line back to the tank.
Here's one of a few places you can ask about them... https://hillsresto.com/ . Last edited by dmsfrr; 01-31-2019 at 02:03 PM. |
01-31-2019, 02:47 PM | #4 |
I thought they used the larger black "garbage can" filters on all E code and F-code cars ? The one pictured I thought was only on T-Birds with the base engine or single 4 barrell non/supercharged engines ?
Don't see the return line to the tank in the picture. It must be somewhere closer to the fuel pump. Sal |
01-31-2019, 06:49 PM | #5 | |
The added fuel return line was made necessary by the higher output fuel pump for the F-code Birds. In the photo I posted above the glass bowl of the F-code fuel filter is 'up' and the return line is straight down, coming out of the center of the filter housing casting. (circled in yellow, photo 2) Reference: CTCI Resto Manual, page 326 #13 (cuz I wasn't sure and looked there) The single 4bbl (and 2bbl) '55/'57 T-Birds used a simpler style fuel filter, photo 3. Last edited by dmsfrr; 01-31-2019 at 07:17 PM. |
01-31-2019, 07:43 PM | #6 |
I must be blind to miss the return line. Thanks for the info on filters. I've learned from this. Just when you think you knew it all. Sal |
01-31-2019, 07:58 PM | #7 | |
I didn't know either until I looked thru my T-Bird convention photos then found the explanation in the Resto book. I didn't see it mentioned but I'd assume there's some sort of pressure relief valve built into the F-code fuel filter. Minter Thunderbirds has been doing high-end restorations on a good number of supercharged Birds for a while now. They could be a good place to ask about parts, but be sitting down if you ask about prices. https://www.amosminter.com/Supercharged_Collection.html . Last edited by dmsfrr; 02-01-2019 at 10:53 AM. |
01-31-2019, 09:58 PM | #8 |
CASCO in Ohio has a help line and they are very accommodating. I believe Hill's (also in Ohio) is the same although I have not used them for questions.
02-01-2019, 07:54 AM | #9 |
Thanks for all the information.
Chuck |
02-01-2019, 11:05 AM | #10 |
Here's a bit more info for your F-code owner friend...
The distributor is/was/should be a Thunderbird and supercharged specific version, part number FEJ-12127-D They are made of 99.9% pure unobtainum. Except for the different part number and having dual points, they look the same as other tach drive '57 T-Bird distributors. photo 2, distributor part number example, FEJ-12127-B2, from an E-code engine. Last edited by dmsfrr; 02-06-2019 at 10:07 PM. |
02-01-2019, 11:56 AM | #11 |
The early supercharged race only version vehicles are dubbed Phase 1 machines.
All of the Phase 1 machines did use the garbage can fuel filter. The pressure relief fuel filter became necessary when the engine was no longer run wide open. There a few differences between the engines the racers had access and what the public was offered. The public got the Phase 2 setups. The distributor is a dual point and has only a 10* slot allowance for timing advance in the guts of the distributor. Oldmics |
02-01-2019, 02:56 PM | #12 |
Great info Oldmics !
Sal |
02-01-2019, 10:09 PM | #13 |
I think all the Phase 1 Birds were "D" birds and are know today as DF Birds. The change to "F" came with Phase 2
02-02-2019, 03:09 PM | #14 | |
http://www.portholeauthority.com/thu...ch/engine.html |
02-02-2019, 03:32 PM | #15 |
Interesting fact is that when the 1957 Ford Chassis Catalog was printed on the date of September 1956 , on the patent plate identifications there was no designation of an "F" code engine.
That leads me to believe that the "F" machines were a late entry and as previously mentioned designated as D/F machines. Then when finally released to the public in June of 1957 they were fully identified as "F" code engines. I have also heard mention that there is/are/were some Phase 1- C/F Birds produced for the race boys.I have to find out more from one of my sources about those C/F Birds. Oldmics Last edited by Oldmics; 02-02-2019 at 09:11 PM. |
02-03-2019, 04:30 PM | #16 |
I have ONE (1) remaining N.O.S. ONLY T Bird w/ supercharger Fuel Pump ---
Will sell it outright w/ No Core required!!! Always best to simply call me --- Craig. 516 - 485 - 1935... New York.. |
02-06-2019, 09:42 PM | #17 | ||
Supercharged '57 T-Birds also aren't mentioned in the Sept. '56 Car & Thunderbird shop manual or this Aug. '56 sales brochure. http://www.oldcarbrochures.com/stati...erbird-05.html However, they are mentioned in this Feb. '57 brochure. http://www.oldcarbrochures.com/stati...7)/image4.html Data plate "F" code Birds were available to the public in the second half of the model year. The earlier (January 25, 1957, Phase 1) D/F Birds were made for racing purposes. (from this link) https://www.supercars.net/blog/1957-...df-code-phase/ . Last edited by dmsfrr; 02-06-2019 at 09:48 PM. |
02-10-2019, 12:41 PM | #18 |
I did respond that I have exactly ONE (1).....
Its' aftermarket part # WAS. 4442 . O N L Y have one (1)..... I know these are not sitting next to the string beans in Any supermarket....... |
05-06-2020, 01:33 PM | #19 |
Craig, I just left you a phone message. I'm interested in the 1957 Thunderbird SC Fuel pump. My email is: [email protected]
808-293-1447 |
05-06-2020, 04:42 PM | #20 |
Hello Martin,
Welcome to the Ford Barn ! I'm not sure if you noticed, but the post from Craig was 15 months ago. I hope he still has the SC fuel pump. You can send him a personal message (PM) by clicking on his ID and then picking personal message. Sal |
