Old 09-29-2019, 08:31 AM   #1
37 Coupe
37 Coupe's Avatar
Default Rear backing plate bolts too long,did search.
I actually found so much helpful information by doing a search on past post on this issue. Three Saturdays go I took off the rear backing plates to send off for rebuild and I never noticed at the time that two out of the four long bolts were shouldered too shallow.These are the four bolts that also fasten the rear radius rod to the rear axle. I really didn't notice anything until I was putting everything back together and two of the long bolts would tighten up with an 1/8" slop. Finally putting the ones that would tighten up and the others I could see how differently they were made almost 3/16" difference in the length of the 7/16" threaded area,all original bolts. I ordered couple from Snyders just to see if they made them correctly and they are enough to tighten down. I figured on the old theory that you cannot go wrong with original parts but this time I was wrong.I also thought mayby the original bolts were made of better material which doesn't matter if they do not fit. The search I did showed this problem over and over again on this forum,only thing I can figure is that Ford or a supplier had a bunch of a big run of wrong fitting bolts and used them up over many Model A Fords or these were an early replacement part made wrong. Mayby in the assembly line it was something not noticed for quite while in the days of no recalls only service letters.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-29-2019, 09:17 AM   #2
Steve Plucker
Default Re: Rear backing plate bolts too long,did search.
Try this 37 Coupe...Maybe this will explain your problem...
http://www.plucks329s.org/pdf/studie...%20BAFFLES.pdf
Pluck
Old 09-29-2019, 09:36 AM   #3
mike657894
mike657894's Avatar
hack job jim here. just take the bolts over to the bench grinder take off a little length then sharpen the bolt at the end so it will thread nicely. Usually doing that will help me find the bracket or washer I was forgetting to put in there. Then to the bolt drawers. To take a bolt that is too long and make that bolt the length of bolt I had before I shortened it.
another favorite of mine in a pinch is to use a bolt that is way to long with a 3 inch stack of washers on it.
mike657894 is offline   Reply With Quote
Old 09-29-2019, 09:47 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
If I was using the backing plate bolts that I had removed , I wouldn't need to do a search , if the short bolt didn't fit right I would try the longer one .
Old 09-29-2019, 01:46 PM   #5
Tom Endy
Tom Endy's Avatar
See attached article.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 09-29-2019, 04:10 PM   #6
alexiskai
alexiskai's Avatar
Tom, where does one get those shims you mention in the article? If they're hard to get, I wonder if putting thin lock washers on the head side of the bolt would achieve the same ends.
Old 09-29-2019, 04:54 PM   #7
History
History's Avatar
Kids got me the ancestry DNA kit, pretty sure you and I share DNA. .
So far I have DNA matches in every state but Maine, Rhode Island and Vermont. I'm sure I have matches there that just haven't taken the DNA test yet.
History is offline   Reply With Quote
Old 09-29-2019, 08:08 PM   #8
37 Coupe
37 Coupe's Avatar
Pluck
Thanks Steve ,great explanantion. Figure #7 would be the parts that mostly look like what I am dealing with that was on my '31 Ford
Thread Tools
Display Modes
