09-30-2013, 02:36 PM | #1 |
8ba piston and ring replacement .
hi guys, I,m looking to replace the rings and pistons on my 51 f1 truck ,a couple of questions before I order them in the u.s to be shipped to the u.k , I havnt found the engineer who will rebore the engine yet ,the bores have a lip at the top so obvious wear . the question is ...do I buy the pistons and rings first and the engineer cuts to the piston size ,if so how do I know how oversize to go , or do I give him the block to measure and he tells me what to order? also I have the carpenter catalogue ,pistons from him o.k or would you recommend somebody else , sorry if the questions sound obvious to you but I havnt done this work before , many thanks , cheers jim.
09-30-2013, 02:54 PM | #2 |
Re: 8ba piston and ring replacement .
I would wait until the machine shop work is done "just in case." Let him tell you what sizes you need. A place you might want to contact for American made is :Egge Machine Co. 11707 Slauson Ave. Santa Fe Springs, Ca. 90670-221 562 945 3419 I am sure they have a web site also that you might check out.
09-30-2013, 03:00 PM | #3 |
Do you know what size the bores are now? It might at least give you a clue as to what sort of sizes you might be looking for. Are you looking for a big overbore or just the first convenient overbore size?
It might be worth talking to Miles at Jackhammer or Kerry Tate or Geordie Paul. They might be able to get stuff cheaper than you can do as an individual. Mart. |
09-30-2013, 03:49 PM | #4 | |
09-30-2013, 03:52 PM | #5 |
before you do any thing take the block to the machine shop and have it cleaned and then magna fluxed to check for cracks, if all is all ok have the machinest mic the bores and see how much it needs to be bored to clean up, then check for availabily of pistons that size, you may have to go a little bigger to find good pistons, egge makes decent pistons, but there quality control some times is poor, i order 8 pistons for my studebaker v/8, when they arrived the pistons lans werent cut in the pistons, for you that would be expensive and time consuming to send them back
09-30-2013, 03:53 PM | #6 | |
09-30-2013, 04:00 PM | #7 | |
09-30-2013, 04:11 PM | #8 |
Your chosen machinist will have to make the call on the next overbore depending on how much wear and the next up oversize to clean it all up. Most machinists will bore to the next oversize just shy of the mark then hone the cylinders to get the piston clearance just right.
09-30-2013, 04:16 PM | #9 |
37coop,the tool you need is called a ridge reamer, check with some of the parts stores, over here they will loan you one for free, with out reaming the ridge it can really be a bit*h to get the pistons passed the ridge
09-30-2013, 04:24 PM | #10 |
Kerry Tate. originalshrs"at"btinternet.com or 0776six70six087.
Geordie Paul trades as Duksville. http://www.duksville.co.uk/ Miles trades as Jackhammer http://www.jackhammerspeedshop.com/ Jim at Royal Customs builds a lot of flatheads for people. http://www.royalkustoms.co.uk/ Mart. |
09-30-2013, 04:30 PM | #11 |
jim..i have a new set for a merc block and crank for 030 bore with the rings...however if you have a ford engine and ford crank you need ford pistons..if you dont see the top of the pistons stamped with the oversize # on them some one will have to probably measure the bore first and determine how much to bore to clean up the walls...before you get too far at least measure the stroke of your crank,,measure with a ruler if you have to,,3 3/4 stroke ford and 4" for merc crank..dont assume nothing..LMK how you progress..thx gary
09-30-2013, 05:32 PM | #12 |
I assume over there you have only unleaded gas? If so, check your block for hardened valve seats. They are needed with unleaded. Ford got rid of them in mid-'50 and added rotators to the valves. They don't do any good with unleaded.
'52 F-1, EAB flathead |
09-30-2013, 05:57 PM | #13 |
Pistons can be expanded if the bore wear is within reason, and if the pistons are in good nick. This used to be a popular method back in the 50s and 60s, I dont know if it is still done. The machinist would have to make the call on that.
10-01-2013, 01:26 AM | #14 |
Bassman, your right , its called knurling,was done a lot back then, but unless the pstons are rare and real hard to get new ones are usually less than the labor to knurl them
10-01-2013, 04:26 AM | #15 |
Be careful with the ridge reamer! Many years ago a friend brought his block to me for re-boring and the oversize required an extra .040 because of his inept use of a ridge reamer.
You are probably seeing the worst of the wear at the top of each cylinder. Inspect the bores to be sure there are no grooves or scratches and have someone use an inside micrometer to find the cylinder with the most wear(largest diameter). Base your piston oversize purchase off of that information. In other words if the wear is at 3.230 buy pistons of +.060. If there are grooves you will need to measure or estimate those depths to determine best oversize to procure. |
10-01-2013, 06:52 AM | #16 |
I had a block with stock pistons. It would not clean up at .020. There was still a bit of an eyebrow at the top. The Egge 4 ring pistons have worked just fine in a stock 49 8BA.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
10-01-2013, 03:47 PM | #17 |
Bore and/or hone the block after the pistons are purchased. Measuring is much easier after the ridge is cut out. If you use an inside mic or snap guage it won't matter...
10-01-2013, 04:34 PM | #18 | |
If you have insert seats in the block, and I think that a 1951 block should- they will be very good seats- don't let anyone replace them. Karl |
10-01-2013, 05:30 PM | #19 |
Badger makes an OEM style piston, with similar weight as the original. They are 4 ring thermal controlled for a very tight fit and come in most standard over sizes. When your machinist measures your present bore I'd go at least .020" larger
10-02-2013, 02:20 PM | #20 | |
