01-18-2020, 09:49 AM | #1 |
1934 steering gear fluid
I am looking for steering gear fluid that does not leak for a 34 4door I am now working on.
01-18-2020, 09:56 AM | #2 |
Re: 1934 steering gear fluid
I use John Deere Corn Head Grease . . . is almost like a thick out and it is wonderful in our early steering boxes! If you want a picture of the 'tube' - can take one when I'm out in my shop later on today.
01-18-2020, 10:25 AM | #3 |
It is thick except when it is under pressure, as between the gear surfaces.
01-18-2020, 10:36 AM | #4 |
thanks --- yes --- send [email protected]
01-18-2020, 11:54 AM | #5 |
Here's a pic of the JD Corn Head grease
01-18-2020, 02:27 PM | #6 |
Paul in CT |
01-18-2020, 02:30 PM | #7 |
JD Corn Head grease is what I use in my Model A steering box...no leak.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
01-18-2020, 03:10 PM | #8 |
just ordered Thanks all
01-18-2020, 03:21 PM | #9 |
PennRite
01-18-2020, 04:17 PM | #10 |
super S cotton picker spindle grease available at tractor supply co. 00 grease same as Penrite but half the price or less...$5.29/quart. Lithium based like Penrite.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 01-18-2020 at 04:47 PM. |
01-19-2020, 07:07 AM | #11 |
fix the leak
01-19-2020, 08:50 AM | #12 |
What is embossed on the fill plug?
If you want the steering box to not leak have a modern seal installed in the sector housing and solder the tube that is in the steering shaft for the horn rod. |
