Old 01-12-2018, 07:22 PM   #1
Grandpa's Huckster
Grandpa's Huckster's Avatar
Default Dashboard wiring question
I took the dashboard off my 1928 and saw a red wire behind it that is disconnected. Anyone know where it should be connected and a reason someone would have disconnected it? The car does have electronic ignition installed in the distributor and I am pretty sure the ignitor is wired to the ignition switch.
Grandpa's Huckster is offline   Reply With Quote
Old 01-12-2018, 08:29 PM   #2
cpf240
cpf240's Avatar
Default Re: Dashboard wiring question
I'd suggest tracing it and see what is on the other end. Any number of things could have been done over the years.
Pictures would help too.. :-)
cpf240 is offline   Reply With Quote
Old 01-12-2018, 08:50 PM   #3
Grandpa's Huckster
I found it. It's not connected at either end. Thanks cpf240 for the comment. It seems the ignitor for the electronic ignition system replaced the red wire in the original harness.
Old 01-12-2018, 09:33 PM   #4
cpf240
cpf240's Avatar
Thank you for the update!
Old 01-13-2018, 10:29 AM   #5
burner31
burner31's Avatar
Wiring
Keith
Shawnee OK
'31 SW 160-B
