03-28-2017, 09:26 AM | #1 |
8BA pistons have 825 stamped on them.
The pistons in my 8ba are stamped with 825. The motor has a rebuild tag from Southern Automotive Engines inc, Owensboro Kentucky, so anyone have any information on these pistons and what size they are?
03-28-2017, 09:30 AM | #2 |
Re: 8BA pistons have 825 stamped on them.
8BA has sleeves?? New to me.
Measure the pistons.
03-28-2017, 12:23 PM | #3 |
.0825mm equals .00324 inches. Could that be indicative of something to do with
cylinder bore or piston configuration? Maybe it was some type of assembly code. |
03-28-2017, 01:01 PM | #4 |
Sounds like some one removed the sleeves. measure the bore.
03-28-2017, 01:07 PM | #5 |
03-28-2017, 03:38 PM | #6 |
03-28-2017, 03:52 PM | #7 |
Measure the piston skirt 90 deg from the pin and tell us what u get.This isn't rocket science.
R |
03-28-2017, 04:03 PM | #8 |
Hey John. New project?
A set of .0825 was on ebay recently... They existed. Just an oddball piston size for when people removed sleeves in earlier engines. http://www.ebay.ie/itm/FEDERAL-MOGUL...-/371014291232
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
03-28-2017, 04:06 PM | #9 |
This guy found something similar in his earlier engine
http://fordbarn.com/forum/showthread.php?t=9601
03-28-2017, 05:36 PM | #10 | |
Sleeve was .040" wall thickness,requiring a hole 3.142" for sleeve. That hole was honed to 3.145" that ended up a 3.0625"+.0825"=3.145" That is smaller than a stock 8ba bore.Can't be the combination op has. R |
03-28-2017, 10:09 PM | #11 |
Good point, I thought it was an early block
03-28-2017, 10:27 PM | #12 | |
Same bore as an 8BA. Bill |
03-28-2017, 11:22 PM | #13 |
03-28-2017, 11:26 PM | #14 | |
