Went out to change the winter to summer pump rod and haven't ran car since Apr 11 and while I was changing rod pumped acc and no fuel squirted in carb from tubes so let teh electric pump rum and took it a few seconds to built the whole line up.So this gas does evaporate out after 16 days but it seemed to back up in fuel line before regulator and fuel pressure gauge.I guess this is normal now also removed thermostats to use this summer.But when gas got to carbs one side if tube did drip onto blades on the base of carbs but after running it looked down and drip had stopped
