Old 11-19-2017, 06:03 AM   #1
rer_239
rer_239's Avatar
Default differential woes
ok got the pinion gear in and "adjusted" put the blue stuff on the ring gear and put that and the empty carrier ass'y in and turned the drive shaft to see how the gears mesh and when turning the drive shaft by hand noticed a clunk (no oil in case but did oil bearings). is this normal?
thanks again
rer_239
rer_239 is offline   Reply With Quote
Old 11-19-2017, 09:23 AM   #2
V4F
V4F's Avatar
Default Re: differential woes
not sure what your clunk is . ive set-up a few & they turn smoothly . try to find clunk .
V4f
V4F is offline   Reply With Quote
Old 11-19-2017, 09:24 AM   #3
Jacksonlll
Jacksonlll's Avatar
No no. No clunk. That's a tough job. It ate us up last yr. Get some help. A ring and pinion shop would be glad to help you.
Old 11-19-2017, 01:35 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
If the axle hubs aren't installed, the axle will move back and forth in the axle tube, but I can't imagine that would make a clunk.
Old 11-19-2017, 02:24 PM   #5
Mikeinnj
Mikeinnj's Avatar
Might want to read or re-read Tom Endys rear end rebuild notes .
http://www.santaanitaas.org/wp-conte...orial-2015.pdf
Mikeinnj is offline   Reply With Quote
Old 11-27-2017, 05:04 PM   #6
rer_239
rer_239's Avatar
just got back to this problem, but it seems like when i turn the drive shaft be hand and the gears mesh and actually touch they would have to click in an empty (no oil) housing. i got one shim behind each bearing and just one gasket (thin) on either side. if i used more gaskets the teeth would be farther apart and would click worse. if i used more shims behind the bearings that would push the ring gear in closer to the pinion gear wouldn't it?
if i pulled the carrier bearings off to put more shims in would i ruin the bearings by taking them off?
Old 11-27-2017, 06:05 PM   #7
1931 flamingo
1931 flamingo's Avatar
What "pattern" are you showing with the blue dye now?? One gasket on each side leads me to think you've not got it "set" right...........
Paul in CT
Old 11-27-2017, 06:43 PM   #8
100IH
A clunk for each tooth engagement on the pinion or one clunk during one complete pinion revolution or one clunk or more for each revolution of the carrier and ring gear.
forget the blueing for now. You have preload on the carrier without pinion to figure out. Were the shims for the carrier brgs.? Its a long process, each step in order.
100IH is offline   Reply With Quote
Old 11-28-2017, 03:25 AM   #9
rer_239
rer_239's Avatar
It clunks when turning the driveshaft a fraction.
Old 11-28-2017, 08:06 AM   #10
Jacksonlll
Jacksonlll's Avatar
Those gaskets are shims and all different thickness. It is a long process. Go find a ring and pinion shop.
Old 11-28-2017, 01:47 PM   #11
V4F
V4F's Avatar
it just takes time & patience . its a process , but not hard . just a lot of assemble & disassemble ......
V4f
Old 11-30-2017, 09:26 PM   #12
jdpalmer
jdpalmer's Avatar
Not sure where you are putting the bearing shims but you have to pre- load the axle bearings without the axles. The bearing shims go under the cone cups not the cone if needed but first you have to determine the pre load. The post above on Santaanis is the best place for this procedure there are no shortcuts
Jimmy Palmer
jdpalmer is offline   Reply With Quote
