Old 11-20-2020, 04:12 AM   #1
Stormstout
Stormstout's Avatar
Default Pinion gears change
Good day everyone!
I am a very proud (yet fresh) owner of a 1953 Mercury Custom. It is a two door sedan with a pronounced whine in the rear axle. Since the car approaches 100k miles, I except the ring and pinion gears are worn out. I thought it would be good to replace them. Could you recommend a source for replacement gears, please, before I dive into it? Also, what other applications use the same setup? Are available gears only for Ford or do they apply to Mercury as well? I have the 255 V8 with 3 SP/OD.
I dabble in electrical Shepparton
Stormstout is offline   Reply With Quote
Old 11-20-2020, 05:27 AM   #2
FortyNiner
FortyNiner's Avatar
Default Re: Pinion gears change
Welcome to the Barn!
I would talk to the smart people at VanPelt Sales http://www.vanpeltsales.com/index.htm
And Randy's
https://www.randysworldwide.com/
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 11-20-2020, 06:45 AM   #3
WABOOM
WABOOM's Avatar
It's probably the carrier berings and pinion bearings making noise, not the gears themselves. Needs rebuilt+ backlash/ preload adjustment by a reputable driveline shop.
WABOOM is offline   Reply With Quote
