Old 11-12-2017, 08:47 AM   #1
wolfords
Default 1936 Ford Pickup
Does anyone know how to remove the door lock from the passenger side?
Thanks!
wolfords is offline   Reply With Quote
Old 11-12-2017, 09:23 AM   #2
37 truck
Default Re: 1936 Ford Pickup
They are held in place by a set screw that is accessible from the door jam. They can be hard to get loose. It helps if you have the key so you can pull on the lock as well. If the set screw wont come out, they can be drilled, just don't go too deep.
37 truck is offline   Reply With Quote
Old 11-12-2017, 09:39 AM   #3
Charlie ny
The set screw has a slotted head not a socket head which adds to the fun, spray it
with KROIL etc if it is stubborn.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 11-12-2017, 04:46 PM   #4
wolfords
Thank you! I thought that was how it works but someone has stripped that screw. I appreciate your response.
Sammy
