11-04-2019, 02:03 PM | #1 |
Oil pressure issues
I'LL give as much as I know at this time and our intentions. The ole' 39 Merc has some miles on her and when warmed up the oil pressure reads "0". 15 when you first crank it. I am planning on dropping the pan and we have a HV oil pump we can install.....Would that be a wise move at this point early in the game?? Any other suggestions as to possible ways to check/clean/increase potential pressure NOT a fresh rebuild.....original to the point OF Not sure if or when it has ever been rebuilt. NO rebuild tag!!!
11-04-2019, 03:36 PM | #2 | |
Re: Oil pressure issues
Another oil presure gauge fitted would be my first choice. Phil NZ |
11-04-2019, 03:47 PM | #3 |
Redoing the carb and fuel filter as the car has sat for most of 2 years so draining the old gas and cleaning and rebuilding the above.....at that point I will add a auxiliary oil pressure gauge at that point and get a "truer" reading when she is back running and report back.
11-04-2019, 04:18 PM | #4 |
My '41 never registered oil pressure above 10. I added after market oil and water temp gauges. OP is always very good.
11-04-2019, 04:36 PM | #5 |
My 48 F6 would show o psi when hot. Ran it for years hauling firewood . Didn't worry about it as long as engine was quiet. Of coarse it had no exhaust so quiet is relevant.
11-04-2019, 07:33 PM | #6 |
https://www.youtube.com/watch?v=QQE_oUExqnE
"Came too close to dying to stop living now!" |
11-04-2019, 08:44 PM | #7 |
With a good mechanical gauge, it should definitely show at lease 10+ lbs at idle - even when hot. I'm not comfortable at all with an engine that shows less than 10 lbs with a good mechanical gauge - if it does, then something is wrong with the oil pump or the bearing clearances. To me, it isn't worth ruining the bearings by NOT knowing what is going on . . . but hey, I'm a bit picky! LOL
11-04-2019, 08:47 PM | #8 | |
If you can find a real/stock Ford pump in good condition, I'd run it. I've seen a couple recent offshore pumps that had casting issues. Most used pumps are actually good - unless the bushings/shafts are shot. |
11-05-2019, 09:21 AM | #9 |
Also, if it has a oil filter check to see if it has a restrictor fitting installed. Lack of one will reduce your oil pressure .
11-05-2019, 09:31 AM | #10 |
Definitely the first course of action...try a different gauge first!
11-05-2019, 11:25 AM | #11 |
Sludge clogging the screen is a high possibly also. Its cost me bearings and cranks for not making sure the oil pump screen is clean.
