10-07-2019, 09:19 PM | #21 | |
Re: Oil In My Water
Lol,,, nice on the gas.
Its going to be interesting to see what this turns out to be. I'll ask my friend when I see him, maybe he knows of some possibility. Quote:
10-07-2019, 09:31 PM | #22 | |
Re: Oil In My Water
Dave / Lincoln Nebraska |
10-10-2019, 03:22 PM | #23 |
Re: Oil In My Water
I've found why I have oil in my water chamber. My number 8 head-stud is stripped, I can not get it to torque. I found it with a double-nut -- so I thought the second one was for holding the distrubtor cable off the head. It wasn't exactly that way. I took the top nut off, when I went to removed the second one, it slipped right off, so it was there as a spacer. Anyway I took the first nut and beganning threading it back on the stud, and that when I found it had an area where the threads in the head stud was stripped. This has to be the problem--
Thanks Everyone for the advise |
10-10-2019, 05:16 PM | #24 |
Re: Oil In My Water
There is no oil in those locations all studs would end in the water jacket if they were open to same, but they are not (normally). Keep looking.
I know the voices aren't real but damn they have some good ideas! |
10-10-2019, 06:49 PM | #25 |
Re: Oil In My Water
10-10-2019, 07:46 PM | #26 |
Re: Oil In My Water
10-10-2019, 08:32 PM | #27 |
Re: Oil In My Water
I believe that that particular stud #8 is different than the others. I remember being cautioned to be sure to drain the water out of the system before removing that stud. If that is not done it is likely that the engine ois could be contaminated with water from the cooling system. Others may be aware of this also. You have probably found the problem. Supergnat
10-10-2019, 09:32 PM | #28 |
Re: Oil In My Water
For what it is worth.
I drove with a few stripped stud holes for a long time. There was 'oil' leaking out the head gasket. It would be logical that combustion gasses would be squeezed into the coolant.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
10-10-2019, 11:47 PM | #29 |
Re: Oil In My Water
He has oil in the radiator not water in the oil.
10-11-2019, 04:02 PM | #30 |
Re: Oil In My Water
OK, here's a short up-date: I began torquing the head. Number 8 was double-nutted, so I took the top nut off, noted that the second (bottom) nut was a different wrench size-- I swapped them out, couldn't get number 8 to torque, found the area of that stud just above the head to be stripped-- the former bottom nut was a spacer, or so it seems. Overnite I left number 8 loose, this AM got a new nut and began by using the bottom nut as a spacer till I can work something better. Now I've finished all my torquing, and checked the dip-stick -- now there's a quart of water in the oil! It must have leaked in during the nite-- so I've drained the oil, replaced the oil and hand-cranked the engine over about a dozen time. And of course brought the radiator level back to normal, ran the engine for a few minutes. Taking a break till tomorrow, when will take it out for a run. This is not going to look good on my Resume !?
