06-17-2018, 05:00 PM | #1 |
Looking for input /opinions
So I’ve been accumulating various parts (McCulloch supercharger , Eddie Meyer aluminum heads , cam,headers , Columbia rear,1940’s ford brakes ,F1 steering,39 trans with zephyr gears ) )for my 1932 roadster over the last year .i told myself I won’t tear the car apart until I have all the parts I was looking for to try and limit the down time . The car is running a 221 v8 flathead .
Here’s where I am unsure . I was debating if I should freshen up the motors internals before I install the supercharger,heads ,cam . The motor runs surprisingly well as is. I just don’t know the back story as far as if /when it was rebuilt , actual mileage etc. This is my first supercharger so I figured others who have run them may have some insight regarding if I should just install it as is or put some fresh internals in my motor to know what I’m starting with. Last edited by draggin49; 06-24-2018 at 11:42 PM. |
06-17-2018, 07:24 PM | #2 |
Re: Looking for input /opinions
Lets just start with a compression test, vacuum gauge says? And whats the oil pressure like when hot..? Go from there.
06-17-2018, 08:10 PM | #3 |
You read my mind. I was gonna ask what specific tests would give me some insight on condition of the motor. I will get those 2 tests done first
06-17-2018, 08:19 PM | #4 |
What talkwrench says, get some data points.
06-18-2018, 10:01 AM | #5 |
Is it an actual 1932 motor?
06-18-2018, 12:32 PM | #6 |
The Frenzel & McCulloch superchargers are relatively tame compared to an appropriate sized roots type but they still give it some boost. I don't know if they can over boost or not. That's a lot of work to go through for the gain your going to get to drive around town. Last edited by rotorwrench; 06-18-2018 at 12:42 PM. |
06-18-2018, 11:33 PM | #7 |
No substitute for cubic inches. I don't think I'd feel confident in putting a second story on a house without understanding if the foundation might fail. Cool or not
06-19-2018, 11:33 AM | #8 |
Yeah, a fresh bottom end would be more peace of mind . That was definitely the way I was leaning even if it’s some extra $$$. You are right I could make a lot more power cheaper with more cubic inch and a traditional overhead v8 . I just wanted to go a different route for something unique.
06-19-2018, 07:46 PM | #9 |
You have to really think about what all these modifications are going to do to the drivability, and how you plan to use the car. When I was a kid and sure I was smarter than the engineers at GM, my 56 Chevy that I drove to Hi-School ended up with a very nasty 327 with triple 2GCs, Super T-10 4speed, and 4:11 rear end gears. Went like crazy in a straight line at full throttle, but with stock brakes and suspension you didn't want to have to stop or turn.
"whatever works!" |
06-19-2018, 08:27 PM | #10 | |
I understand. I was just saying if the bottom half will hold up or not. Maybe for quite a while. I don't know. Will be a nice setup. little irrelevant story.. I acquired a 62' 390 caddy motor that came out of hearse. Super clean on wear but was sludged' up from low miles and low rpm. I let it go because it was taking space, and I know I am a flathead guy. But dang!!! Learned later the guy let it sit out in the rain and ruined the block. douchedag as he would said he'd use it. I should have kept it... water under the bridge I guess. Last edited by Tinker; 06-19-2018 at 09:22 PM. |
06-20-2018, 02:37 AM | #11 | |
Today’s road speed (freeways ) are much higher than what they were back in 1932. My stock 4:11 rear makes the motor buzz pretty hard at 55mph . I have opted to have a Columbia built . It will let me keep the low gearing to get the most out of the flathead but allow for any freeway time or wide open highway to be done at a MUCH lower rpms. Now with the ability to go a higher mph stock brakes would not be the best decision. I have decided to upgrade the brakes on all 4 corners to better handle this additional road speed. |
06-20-2018, 02:43 AM | #12 | |
06-20-2018, 07:54 AM | #13 |
Sounds like you accumulated the mother lode of rare (and therefore expensive) period-correct Ford add-on parts to be placed in a valuable car.
Why skimp on the rest of the job? A set of bearings , rings, new oil pump and gaskets are cheap and relatively easy to do. |
06-20-2018, 07:57 AM | #14 |
And the dreaded "project creep" again rears it's ugly head.
06-20-2018, 09:27 AM | #15 |
The McCulloch superchargers of that vintage had their ups & downs. McCulloch updated them as problems showed up. One was oiling. When the oil gets broken down by use, the blower starts to get noisier. They improved it early on but the worm screw drive has a tendency to wear rather quickly and the gears are unobtanium. Folks that want to use them have been having new gears fabricated by machine shops that specialize in gear hobbing and the like. I think material shortages in the early 40s sort of shut the project down at McCulloch so it only lasted for a few years. They still made superchargers but mostly for military applications. After the war, McCulloch started a company using his middle name Paxton. Those superchargers were manufactured for a long time in various configurations & model numbers.
06-20-2018, 10:27 AM | #16 |
This is a copy paste from a reference note I keep. Talking about the late Paxton, McCoulagh , but petty sure he has more exposure to these than most of us.
You might call Craig Conley at Paradise Wheels. He bought all the old ball drive Paxton stuff. There's John Erb, NV, I think, that's well regarded for rebuilds. Myers Studebaker was also helpful in identifying parts and carb options. http://www.paxtonauto.com/article.php?id=155 http://www.myersstudebaker.com |
06-20-2018, 12:37 PM | #17 |
I have a perfectly good running stock 8BA and installed a S.Co.T. blower on it. I wanted to have everything set up correctly before modifying the engine. It took a lot of thought and fabrication to fit into a 32. My new plan is to leave as is till it needs rebuilding or I get bored.
If you decide to go this way just don't push that early flathead too hard. Last edited by solidaxle; 06-20-2018 at 03:29 PM. |
06-20-2018, 12:48 PM | #18 |
I guess at my age and tons of cars over the years etc. My suggestion would be use what ya go , put it together and enjoy it.... just drive it and let it tell ya what you need.
Your other options are $$$$$$$$ to open pandoras box etc would cost a fortune for very little gain etc..... |
06-20-2018, 06:28 PM | #19 | |
You’re right , no reason to skimp , I’m just gonna take the extra time and do all those things you mentioned and the other items I can freshen up . Last edited by draggin49; 06-20-2018 at 06:37 PM. |
06-20-2018, 06:31 PM | #20 | |
Yeah , there’s definitely some work to fit that into a 32/make it work. |
