05-21-2018, 09:39 AM | #1 |
49-53 Loadamatic Vacuum Chart...
There was some discussion in regards to the vacuum levels needed for a
load a matic distributor operation. Heres the charts and a article on how it works. |
05-21-2018, 01:26 PM | #2 |
Re: 49-53 Loadamatic Vacuum Chart...
Is it the same for a stock 53 Merc.?
05-21-2018, 03:10 PM | #3 |
Pretty much the same .....
05-21-2018, 05:11 PM | #4 |
Thanks. Jim T.
05-21-2018, 09:33 PM | #5 | |
Thanks Bubba. Yes, Loadomatic is very year specific. My old Holley manual shows the advance curves for different model years and carbs, and they all vary slightly. The carbs all give a slightly different amount of vacuum, plus the distributors can have different springs in them. My gutt feeling is that you can mix and match different year carbs and distributors as long as they are all Loadomatic style. Sal |
05-22-2018, 04:25 PM | #6 |
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
05-22-2018, 06:18 PM | #7 | |
Which vacuum level is on the text? 1.at venturi and 2.at throttle plate which translate to - 1. disty input or 2. wiper vacuum? Did you mean to post a chart per your post or just the text? As I will use a calibrated vac gauge, it makes difference to achieve the numbers at rpm listed. |
05-23-2018, 07:04 AM | #8 | |
